540i M Sport Pkg w/ DINAN Upgrades, LOW MILES, VERY CLEAN
For sale is my 2002 E39 BMW 540i M-Sport Package in Sterling Grey Metallic with dealer-installed DINAN performance upgrades earning it a 'DINAN 5' designation. The car was purchased with 81,136 miles in January 2018 as a then 1-owner car that spent it's entire life in Orange County, CA. It currently sits at approx. 99,300 miles. As a longtime BMW enthusiast who have only owned coupes/convertibles, my intent was to make this my forever Bimmer highway family sedan cruiser, especially given the E39 generation is a fan favorite and quickly becoming a future classic. That said, shortly after taking ownership, I undertook a project to fully restore/refurbish/enhance the car mechanically and cosmetically (exterior & interior) to bring it to like new OEM+ condition; after a year and approx. $13k (8k parts + 5k labor) spent, the car was complete. I have a binder of all receipts documenting parts purchased and repairs performed under my ownership. Recent AutoCheck vehicle history report showing no accidents can be supplied. Car comes with 2 sets of master keys and all original books/manuals. Smog was completed late November 2019. DMV registration paid through early December 2020. The car must be seen in person to be appreciated. I welcome all questions. Open to pre-purchase inspections. Located in Newport Beach, CA.
PHOTOS: https://orangecounty.craigslist.org/...054881920.html
Message me for more photos.
Cosmetic Condition: For an 18 year old car, I would rate the exterior and interior a 9/10. There very few/minor rock chips on the front hood and some hardly visible blemishes along the side exterior. There are NO dents/dings or any major scrapes/scratches/cracks in the paint work. The exterior glossy Shadowline trim pieces are not faded and no rubber door/window seals are cracked. Headlight has been restored & protected with clear vinyl film. The interior leather front & rear is super clean with no tears in any leather upholstered areas. The upper black dash area and upper door panel areas are not faded and free of damage. There are ZERO dead pixels (common issue) in the instrument cluster or in the HVAC display screen. Sunroof/moonroof operates flawlessly and so does all the windows.
DINAN UPGRADES: Installed at Long Beach BMW early in the ownership of 1st owner. High Flow Air Meter, High Flow Throttle Body, High Flow Intake Manifold, High Flow Cold Air Intake, DINAN Engine Tune Software v5.06, Aluminum Strut Bar, DINAN floor mats. The car also came with a DINAN muffler that was removed to accommodate the OEM M-Technik rear bumper diffuser. DINAN rates the car at 320hp/340tq.
Summary of service/repairs/parts
March 2018 (~82k miles) -- used new OEM or factory BMW parts only
ENGINE
- Vanos solenold seal
- Valve cover gaskets
- Intake manifold gasket, throttle body gasket, PCV crank case valve gasket
- Valley Pan w/ gasket, air filters x2
- Timing: lower timing chain tensioner, 3 timing chain guides (critical common weak point), front crank shaft seal, lower timing case gaskets, upper timing case gaskets
- Drive belts/Pulleys: water pump/alternator drive belt, AC drive belt, tensioner
- Oil pan upper & lower gaskets
- Cooling System: radiator, water pump, thermostat, expansion tank, hoses (engine, expansion tank x2, water pipe, upper radiator, lower radiator, transmission cooler)
- Engine mounts (July 2018 @ 86k)
- Spark plugs
- Routine Mobile 1 5w/30 oil and filter change every 5k miles
POWER STEERING
- Hoses: suction hose, return pipe, oil carrier, pressure hose assembly, clamps, O-rings,
- PS fluid change
- Pump & pulley (replaced 3/2019 @ 92k)
TRANSMISSION
- Guibo/universal flex disc
- Fluid flush w/ Redline D4 ATF & new drain plug, fill plug
- Oil filter w/ gaskets
- Transmission mounts (July 2018 @ 86k)
DIFFERENTIAL
- Fluid change w/ BMW-Castrol SAF SAE 75W-90 fluid
BRAKES
- Brake flush w/ ATE DOT 4 fluid
- Zimmerman front rotors & Akebono Euro Ultra Premium Ceramic low-dust pads
- Zimmerman rear rotors & Akebono Euro Ultra Premium Ceramic low-dust pads (replaced 5/2018 @ 85k)
SUSPENSION
- E39 M5 KW ST adjustable coilovers (replaced 5/2018 @ 85k): front/rear shocks struts, springs
- Front: left/right wishbone, L/R thrust control arm, L/R outer tie rod
- Rear: guide link, L/R wishbone, swaybar endlinks, L/R wheel carrier ball joints, L/R integral links w/ bolts/washers
FACTORY M5 / M-TECHNIK AERODYNAMIC KIT
- OEM E39 M5 Front bumper + mounting hardware & required parts (e.g., air/brake ducts, mouldings belly pan cover)
- OEM E39 M5 Rear bumper + mounting hardware & required parts (e.g., fender liners, mouldings)
- OEM E39 M5 rear lip spoiler
- Shadowline exterior door mouldings
- Replica E39 M5 side mirrors, power folding, heated (stock mirrors included with sale)
- OEM 18" M-Parallel wheels w/ Sumitomo HTR Z III tires (June 2018 @ 85k miles)
MISC REPAIRS DURING 2-YR OWNERSHIP
- Professionally reupholstered sagging grey headliner, sunroof shade, rear parcel shelf with: new black Shadowline headliner fabric. Replaced grey headliner components (grab handles, sun visors, dome lights, reading lights) with black Shadowline components
- Replaced interior wood trim w/ Technical Graphite trim for sleeker/sportier appearance
- Replaced single-disc CD player and factory radio (included with sale) with Android Double DIN headunit (Google Maps, Gmail, bluetooth, Navigation, Youtube, etc apps)
- Repaired rear windshield power sunshade w/ new slider brackets (common failure)
- Replaced broken manual sunshades at rear L/R windows & quarter windows
- Repainted faded exterior door handles
- Replaced cracking front cowl w/ new cowl
- Replaced cracking rear windshield weatherstrip/moulding w/ new part]
- Replaced driver side window regulator
- Headlight adjuster kit (common failure): replaced low beam & high beam adjusters for both L/R headlights
- Sticky accelerator pedal (common issue): replaced w/ revised pedal and adaptor plate
- Replaced windshield wiper blades w/ new Bosch blades
- Replaced windshield washer pump
- Replaced faded front Roundel badge
- Replaced door entry trim sills with OEM ///M door sills
- Replaced worn trunk struts w/ Stabilus struts
- Replaced worn glovebox compartment strut
- Replaced center console storage compartment
- Replaced center armrest phone tray trim
- Replaced center vent
- Refilled A/C refrigerant
- Added instrument cluster silver accent gauge rings
- Added interior rubber floor mats front/rear & trunk
- 35% window tint
2006 E53 X5 4.8is
2007 E86 M Coupe
1997 E36 M3
2006 E85 IB M Roadster (sold)
2002 E39 540i (sold)
2013 E89 Z4 sDrive35i (sold)
2011 E92 M3 (sold)
2001 E46 M3 (sold)
2002 996TT (sold)
2007 R56 Cooper S (sold)
2009 E82 135i (sold)
2006 E85 BSM M Roadster (sold)
2003 E46 M3 (sold)
2002 E46 325Ci (sold)
