Hi guys,
Wondering if any of you have experience with water gathering in the sunroof cassette and entering the vehicle?
Is it normal for water to enter the cassette on the basis that it should drain away, or is the sunroof designed to be completely water tight? I’m trying to determine if this is a drainage issue or a seal issue.
Any advice would be much appreciated.
Cheers
The drains are there because the sunroof seal is never 100% watertight. That’s the way it’s designed.
Mike Barrett
94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
96 850Ci, Oxfordgrun over silbergrau hell
Your drains are probably clogged. It is probably both a drain and a seal issue. Replace the seal and clean out the drains.
On closer inspection it appears that the drainage holes were blocked. Thanks for the feedback.
