Results 1 to 6 of 6
Thread: Long shot, need a connector to E36 ABS pump
    Aug 2012
    Central, MD
    1995 M3
    For a 95 E36 M3, but I think any year E36 will work....
    If anyone has a spare connector that attaches to the ABS pump, I need one.
    This is the 'car side' connector (not the side that's physically attached to the pump), X31 in the ETS.
    Richardson, TX
    F150, E36 M3, 67 Fbird
    May be on this page
    https://www.carid.com/1995-bmw-3-ser...er=1&sub-model[ourRealModelName][]=325is
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    I bought mine on ebay from a scrapper. Consider messaging the folks parting cars on this site as well. The connectors are NOT all the same between the 3 channel and 4 channel systems (well the connectors are the same but pinouts are different).
    What are you trying to accomplish?
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    Good idea.
    I have a 95 3-channel. So no way to bleed the ABS pump. I simply want to make a connector so I can power the solenoids and pump while bleeding the system. About 6 grounds (to the solenoids) and 2 12v connections needed.
    Springfield, IL
    I use a short jumper wire with spade connectors at each end to jump the "abs pump" relay. Not sure if you have deleted this relay or not but mine has a dedicated ABS relay and a dedicated "ABS pump" relay that the ABS module triggers the ABS pump with.
    Aug 2012
    Central, MD
    1995 M3
    Yea, I do that too. But it doesn't cycle the solenoids. 6 in my case. Which means there are some passages in the ABS unit that are closed.
  1. 99 E36 ABS pump cycling - Need simpel tool to do cycling
    By bmellott in forum Diagnostic Software
    Last Post: 06-24-2015, 02:53 PM
  2. E36 92 E36 ABS Pump
    By rao in forum Brake Kits, Rotors & Pads
    Last Post: 04-22-2010, 11:50 AM
  3. need help w/94 E36 ABS wiring problem
    By Laze1 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 07-13-2009, 07:38 AM
  4. long shot.....need cosmos fender in socal
    By turbosporttsi in forum California sponsored by Avus Autosport
    Last Post: 07-29-2006, 12:12 PM
  5. E36 ABS Pump removal - Need Help
    By skrissel in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-19-2005, 10:34 AM
