e46 auto to manual swap after program and encode fault 27EC stored = check engine lig
Car is a 2003 e46 wagon
original 2.8 i think with auto
swapped zhp and manual trans
flashed with 7 561 520 file per realoem zhp with manual that matches production date.
deleted $205 from VO
FA_write cluster and lamp module
coded cluster, lamp module and ews
cars check engine light after second drive cycle - fault is entered imitatively after clearing
(I've verified programmed part number as well)
Ive only done one other auto to manual program/coding and was successfully, only get the S 0012 No communication possible with: Transmission control unit. this one does not set check engine light, cruise control works and vehicle passes state inspection. When doing a short test with ISTA/D, EGS is yellow (not responding) since ecu is not there. Not sure if the vehicle type code in the vin number sets auto/manual or not. That fault is not the problem, its the 27EC.
Not sure whats going on with this wagon, if anyone knows what to do, please enlighten me as the internet does not have solutions for fault 27EC
Thanks,
Clint
2006 X5 L83 5.3 6l80 swapped in progress
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
