Hi I have a 03 330xi that is missing super bad I use to could just stop car turn it off and go under hood unplug the maf and plug it back up a restart car and would drive fine for awhile and have to do same thing again when it started missing again now that’s not working and replaced the maf that didn’t fix my problem I’m getting lean bank 1 and 2 codes along with missing codes random multiple misfire no Specific cylinder any ideas? I was thinking maybe the camshaft position sensors? Help plz
Check all your intake plumbing and vacuum lines for leaks. Even a small intake leak can make them run pretty poorly.
The first step in diagnosing a problem is to scan the engine computer (DME) for codes.
16 year old car. Look at the intake bellows by the MAF any cracks there? squeeze it and look for cracks that might open up. Maybe find someone to run a smoke test for you. Sounds like you've got a leak somewhere.
Marc Plante
E36 M3/4/5 193k
Konis+ Dinan Springs, Understeer SS, Shepott European steering Wheel, ZKW Ellipsoids, ECIS Intake+ ATE Foam filter, Stromung Exhaust, Recaro SRDs. JVC Arsenal Head Unit. Alpine MRV-F300 Amp, ADS 535i components, JL Audio Stealthbox Subs
My Track Rig:
i7700 / 2080 PC with Assetto Corsa and Content Manager, Samsung Odyssey+ VR goggles
Fanatec CSP wheel and pedals, SSH Shifter, recaro seat. Home built cockpit
Mt Pleasant, SC, USA
+1 : You have a large intake / CCV system leak. Take the car to a good Euro/BMW shop for a smoke test of the system, plus a crankcase vacuum test.
Chris Powell
BMWCCA 274412
