Hi All,
I am in the process of starting my E36 LS1 swap. I will be using CX Racing swap kit and was going to change the motor mounts bushings due to seeing some members having premature failures with them.
I have went through the whole Energy Suspension site and could not find any bushings similar in size. Can someone make a recommendation on how to proceed? Any other vendor, another path, etc?
Current CX Racing bushing dimensions are:
Od - 28mm (1.1in)
Id - 17mm (0.7in)
Length - 49mm (1.9in)
Overall length - 62mm (2.45in)
Thank you in advance
I was able to actually find the closest bushing made by Energy Suspension. I only had to cut it to correct length. ID,OD were nearly the same. Part - Bulk-2008
