RM European Auto Parts
Results 1 to 7 of 7
Thread: E46 - Weird Rattle - No Error Codes
    Dec 2018
    San Diego
    2013 328i, 2002 330i
    Weird rattle on cold start and rev. Seems to diminish a little bit as engine warms. No error codes. Any ideas?
    Jan 2016
    Ca
    2001 525it
    Check the engine oil level
    Dec 2013
    Chicagoland area
    EXOTICS
    Check for radiator cooling fan and shroud making contact with each other.
    Michigan
    2005 325Xi
    How many miles? Any recent work? Any indication of the approximate location of the noise? From my computer speakers, that noise is indecipherable. I can hear something, but it sounds more scratchy than rattle-y.
    If the fan blade is contacting the shroud, the waterpump is toast. But it may just be the idler pulley bearings. Or it could be the belt tensioner.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Dec 2018
    San Diego
    Here's another video....
    Noise at startup and under acceleration. Sounds fine at idle. No error codes. I thought maybe the starter wasn't disengaging all the way but it's weird there is no noise at idle. Another thought was cracked flex plate but it looked fine when I had it off recently.
    I'm gonna try to start it and run it without the belts and fan clutch to try and rule out any tensioners/belts etc.
    Dec 2018
    San Diego
    I figured it out. I ended up having to shim the aftermarket starter I got on rockauto.
    Michigan
    2005 325Xi
    Thanks for the update
  1. PLEASE HELPP (BMW 318 2005 E46 dashboard weird error code)
    By mylifeuncutt83 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-13-2011, 04:22 AM
  2. BMW 318 2005 E46 dashboard weird error code
    By mylifeuncutt83 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 06-12-2011, 08:14 AM
  3. Fault 2761 error code e46 325ci
    By ronk in forum 1999 - 2006 (E46)
    Last Post: 03-11-2009, 03:46 PM
  4. Weird Oil Leak / Error Codes !!! Take A Look !
    By alexkid in forum 1996 - 2003 (E39)
    Last Post: 10-14-2008, 07:02 PM
  5. Getting weird error codes when I have no problem???
    By AaronM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-16-2003, 12:03 AM
