RM European Auto Parts
Results 1 to 10 of 10
Thread: 2004 bmw x5 4.4 sensor question.
    Mar 2017
    Missouri
    2000 bmw 528i, 2004 bmw
    Okay so i have a 2004 bmw x5 with the n62 and i just removed the engine to do the valve seals, rear main seal and alternator bracket seal. I got everyting put back together and the car fires up but idles rough but doesnt die. I plugged in my fire fox scanner and I get codes
    p0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
    P0024 - "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    And a muiltple missfire code.
    So my question is which sensor should i be looking at? The eccentric shaft sensor correct? I had noticed a crack on one of the mounts putting it back together but after looking at the price i was hoping the valve cover would hold it in place properly until i could afford one. And bank two is driver side correct?
    Jan 2016
    Ca
    2001 525it
    Seems like valve timing is off
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    Yeah I would double check the timing, for that is what you are getting codes for. Did you replace the chain and guides while you were there? The V-8's tend to be rather hard on them, and typically after 150k miles start to show.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Definitely sounds like the timing is off.
    Mar 2017
    Missouri
    I did not touch the timing all chains where still tight. I used gst's valve replacement tool kit, that doesnt require you to remove timing chains, cam, or any chain guides.
    Also what makws me believe its sensor related, is after a minute of rough idle itll smooth out or if i used my code reader to clear the codes, the idle will immediately smooth out.
    If i rev it, it struggles to about 3k amd then is fine. I have not taken it for a drive.
    Maybe you swapped the cam sensors or connectors
    Mar 2017
    Missouri
    Quote Originally Posted by White94RX View Post
    I can give it a try. Can you give me a better idea of which two you think i got mixed up?
    The two cam sensors are on top of the valve cover at the back
    Mar 2017
    Missouri
    Those two are both in the correct location. The plugs are different for bank 2 so its hard to mix them up.
    Mar 2017
    Missouri
    Okay, so i replaced the eccentric shaft sensor from fcp and that took care of my p0022 code.
    The car will start without hestitaion and idle funny for five seconds and then smooth itself out. And a check engine light will pop up flash a couple times and diappear with the rough 5 second idle. I caught the code and its giving me p0024 still. Itll idle fine until i hit gas and then it cuts out until i get pass 2500rpms.
  1. FS: 2004 BMW X5 3.0i | Sterling Gray | VIN#5UXFA13504LU39660
    By JaySpec7 in forum BMW Cars For Sale / Wanted
    Last Post: 10-17-2006, 09:23 PM
  2. 2004 Bmw X5 Complete For Parts L@@k
    By partsman in forum BMW Parts For Sale
    Last Post: 12-21-2004, 10:42 PM
  3. 2004 Bmw X5 Complete For Parts L@@k
    By partsman in forum BMW Cars For Sale / Wanted
    Last Post: 11-24-2004, 08:40 AM
  4. 2004 Bmw X5 Complete For Parts L@@k
    By partsman in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-24-2004, 08:39 AM
  5. 2004 Bmw X5 Complete For Parts L@@k
    By partsman in forum BMW Parts Wanted
    Last Post: 11-24-2004, 08:38 AM
