I might be parting out a 540i soon. Wondering if I should convert the Imola Wagon to a 540? Worth it - yay? nay?
Why not?
It’s a heck of a job but if you have the time, space, patience and most importantly the knowledge, then why not?
Personally I think it will be cool. Especially if you can get a manual box for if and prepare it for a blower of some sort (Turbo or SC)
Deepan
For day to day driving, I'd keep it Auto, but for sure future S/C and things like paddles, tranny tune, 3.15 LSD, etc. Shouldn't be way too tough as far as mechanical stuff. Take out complete drivetrain including front sub frame.
Issue I wonder about are things like steering box, etc.
Meh.... lots of those out there now. With M62TU, no need to cut up the rear section for dual outlet exhaust.
Would it be any more involved than an S62 Swap? The hard parts should pretty much bolt up. Big difference is front sub frame from I6 - V8. I'd also replace the front radiator mount and such and save time fiddling with the I6 cooling stuff, etc.
Cheers for the offer mate, but no need of a 5HP30 box. I'd have a complete drivetrain - M62TUB44 plus the 5HP24 still attached to it.
Yeah - Know a few guys doing the S62 swap. Lot more involved. You also gotta do pedals, clutch slave, etc. I figured with the I6 - V8 swap, since both as Auto, there is slightly less electrics to modify. Swap out the DME, AGM and such along with the donors EWS, Ignition and Key. Might even swap out the driver's side door barrel so car only needs the one key.
Then get the LCM and GM programmed to the new ECU and such and she should theoretically fire up thinking she's a V8 straight outta Dingolfing.
Ahhh.... this is a TU, and both cars are 2003 making them emissions legal and all that over here. Shipping from the UK would cost an arm and leg, and possibly a first born child too!
Do an EWS delete while you’re there. Makes sense and saves you a bit of hassle with less electrics to worry about. The other modules can be virginised and coded to the receptive VIN. Then also you won’t need to swap locks and stuff.
Still bits to relocate in the bay too. As well as servotronic steering, the gearbox and power-steering coolers etc (is go aftermarket with those - mocal or such like.
Personal preference would be twin chargers instead of SC but that’s only if funds allow
Good idea on virgnizing the modules. Still need M62TU DME and the AGM. The Steering Box is one of the things I wonder about. As for the transmission cooler and such, I'd just swap out that whole front end from the 540 to the 525. Can pull the whole assembly out together.
You can cut open the keys and swap the boards so you can use the original key that goes to the cars ignition and door cut...
No but how "easy" is an EWS delete on the Me7.2?
That’s the part I’m still trying to figure out in the 540iA.
Technically if the donor engine has it already, it shouldn’t matter, but for completeness I’d prefer to do it. You can send it away to a company to do it, but I’m not sure who over that way I’m afraid
Yeah! I programmed it to my cars VIN and ZCS and then flashed my DME using Terraphantm's modified files that enable the tach lights and oil temp. Since then I have had another Me7.2 wizard delete the MAP cooling sensor for my 88c mechanical tstat which curves the aux fan activation a bit more and an SAP delete too...
Terra has modified some 540 files for the same m5 cluster retrofit as well...
