Results 1 to 3 of 3
Thread: Why high Main crank bolt torque
    Aug 2017
    New Zealand
    1997 BMW 728i
    I am replacing the timing chain guides on my 2001 540. As most users, I had great difficulty getting the crankshaft bolt off, but got there in the end
    Now I am considering why I have to replace the crankshaft bolt and why it is torqued so high.
    I understand that if the bolt is torqued as per bmw spec it may stretch the bolt and weaken it.
    Many posts say they have reused bolt, and i understand why as it is US$ 60 to buy in US and ship here to new Zealand
    But why does the bolt need such a high torque? All it does is hold the harmonic balancer pully?
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    To keep it from falling off at high rpm. Don’t fool with that. Look at the cost as an insurance policy. If it all comes apart on the road because you used a part that was not meant to be reused, the cost above is nothing. This is one of the reasonable costs of German engineering.
    Jan 2016
    Ca
    2001 525it
    Don't go cheap now, buy the bolt, its not for you to know the reason, just replace it.
  1. m42 crank bolt torque spec?
    By immajackuup in forum 1983 - 1991 (E30)
    Last Post: 04-23-2012, 11:14 AM
  2. Replies: 2
    Last Post: 01-07-2012, 02:54 AM
  3. Main crank bolt torque spec confusing
    By moroza in forum 1988 - 1996 (E34)
    Last Post: 12-12-2009, 07:55 PM
  4. Main crank bolt torque spec confusing
    By moroza in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-12-2009, 12:49 AM
  5. Main Crank Bolt LOOSE !
    By TallKDR in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2004, 04:04 AM
