Results 1 to 15 of 15
Thread: Headlight Auto leveling lights
    Jan 2020
    GB
    2006 BMW e91 touring
    Hi, I have a 2006 BMW e91. Only recently bought. The headlight seem to be pointing to the ground, on both Auto setting and normal On setting.
    I have looked for the sensors but can't seem to find them. Any help is appreciated!!
    Sent from my SM-G975F using Tapatalk
    Mar 2006
    CT
    E30
    LF control arm and lr control arm
    Jan 2020
    GB
    Quote Originally Posted by KDss14e30 View Post
    Did think that from what I found on other forums, but couldn't see them on my one, which I found quite strange
    Michigan
    2005 325Xi
    PO may have put self-leveling headlights in a car without self-leveling.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Jan 2020
    GB
    Quote Originally Posted by Critter7r View Post
    Is there away of either manually setting the projectors, or adding the sensors?
    Or the car doesn't have them. Just use the manual adjusters to raise them. It's on top of the headlamp.
    Do the headlamps go down and then back up when you turn them on?
    May 2017
    Ontario, Canada
    335i E93 N54
    Very weird to install self leveling in a non-supporting car. Likelihood is small, but exists.
    As White94RX asked, check if they move upon turning on the ignition with lights on. (should point down, then level)
    If stuck down, they will do this if a sensor is faulty, for safety of oncoming traffic.
    I put my money on you having the sensors and just haven't located. (alternately someone got silly when replacing parts)
    Michigan
    2005 325Xi
    Quote Originally Posted by Codes2 View Post
    Which is a really dumb default position for BMW to set, since it means you can't drive the car at night after a sensor gets broken off by running over a raccoon. The default when there's no signal from the sensor should be the standard center position (the one it would be in if there wasn't a self-leveling system) and an illuminated warning light, not two useless headlights pointing at the ground.
    Jan 2020
    GB
    Quote Originally Posted by White94RX View Post
    Have looked for the thing to manually adjust them, but the headlights doesn't seem to have it, doesn't look like a genuine headlight unit. The light don't go up and down on start up
    Mar 2006
    CT
    E30
    Post pics of headlights ?
    Jan 2020
    GB
    Some photos of drivers side
    Michigan
    2005 325Xi
    Looks like the up/down adjustment is on the backside of the housing, and the left/right adjustment is accessed thru the slot in the fender.
    Jan 2020
    GB
    Can someone send me a link to the correct bulbs. I know it should be simple, but I think a previous owner and cut standard bulbs out and put after market HIDs, and they don't fit the cap where the bulb sits in. So bulb was facing down which wasn't helping.
    What a mess. They don't look like OEM headlights. Now you've got to solve someone else's hack job.
    Jan 2020
    GB
    I know, hate wiring at the best of times!
  1. Issue with headlight auto leveling after drop
    By 525iT_Feen in forum 1995 - 2001 (E38)
    Last Post: 05-09-2010, 12:23 PM
  2. Auto leveling lights and lowered suspension?
    By teedub21 in forum 1996 - 2003 (E39)
    Last Post: 01-15-2009, 02:17 AM
  3. E39 99 E39 OEM Hella xenon headlights auto level
    By ADOBO in forum Exterior Lighting & Body Parts
    Last Post: 12-11-2008, 03:48 PM
  4. Possible to retrofit Auto-leveling lights?
    By tdawg183 in forum 1996 - 2003 (E39)
    Last Post: 10-23-2007, 09:11 PM
  5. Do any of you with P39's miss your auto leveling lights?
    By Holeshotz8436 in forum 1996 - 2003 (E39)
    Last Post: 08-05-2007, 07:22 PM
