Results 1 to 7 of 7
Thread: Z4M would crank but not start after a successful jump
    Los Angeles, CA
    '06 BMW Z4 M, '06 X5 4.4
    I jumped my ‘06 Z4M a few days ago after I let it sit for over 2 months (with only one start in between without letting it run enough). I started it tonight, which would have been the first start since the jump, and on the first try, it cranked for a good 10 seconds but didn’t start. I closed the ignition, waited for a few seconds, and it started just fine. It started normally 2 times after that. Is this a sign of a failing fuel pump or just a glitch from a jump?
    Miamisburg, Ohio
    1997 328iC, 2003 Z4
    Did you just try to start the car or first put the key in the on position and wait? If you don't wait the fuel pump can't get the system back up to pressure so it wouldn't start right away.
    Jan 2016
    Ca
    2001 525it
    The fuel system needs to fill and then when it does start it will probably run kind a crappy for a number of minutes also if it's going to sit put a battery tender on the battery, jumping a dead or very low battery is not good, charge the battery and start it again
    Los Angeles, CA
    Thank you!
    Likely a small vacuum leak somewhere
    PRICE CUT on ALL FABRICS
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Or a soft failing inlet camshaft sensor?
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Dont know why that would be a cam sensor
    The fuel system works on vacuum to hold pressure. It there is a vacuum leak the fuel pressure regulator will drop pressure after sitting. Eventually itll drop pressure to "0" and when you go to start it takes longer than usual because it has to build fuel pressure. On consecutive starts it didnt have enough time for fuel pressure to drop all the way so it started quickly since there was residual pressure from having just started the car
  1. E32 cranks but does not start after sitting for 3 days. New Battery.
    By The Texas Sun in forum 1988 - 1994 (E32)
    Last Post: 07-03-2019, 01:11 AM
  2. s50 cranks, but will not start after swap, help!
    By RiCoZM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-25-2008, 09:06 PM
  3. Help: Will not start after crank pulley install!
    By caldweb in forum 1992 - 1999 M3 (E36)
    Last Post: 07-15-2004, 08:28 PM
  4. '92 325 cranking but not starting
    By MickFly in forum 1991 - 1999 (E36)
    Last Post: 12-08-2003, 08:43 PM
  5. Car not starting after an accident???
    By njkode in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-25-2003, 10:17 AM
