Does anyone have the instructions to install hardtop mounts & connectors? If not could someone show me a picture of how the mounts should be placed onto the bracket. Thank you!
the mounts have a R and L on the bottom The L is left looking from the rear. There is an arrow that points to the front of the car I can send you instructions if you like. email me at z3hardtops@gmail.com
the top plastic bushings will only go one way because of a notch in the corner.
The instructions would be nice I just need to figure how they’re placed on the bracket. I just sent an email for the instructions.
Hammer is correct and you have to fish the brackets UNDER the mounting area and then drop the bolts through the top. Then run the wires down and around all the linkage to prevent the linkage from chopping the wires. Fish them inside through the hole and then to the plug next to the other vert wire connections.
