Page 3 of 49 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 1220
Thread: What did you do to your E38 today? *retired for new year
  1. #51
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Long time no see
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  2. #52
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by NordmanMg View Post
    Long time no see
    Looking good, as usual...
    Pulled the oil pan in the '96 because of some rattling sounds from below. Was worried maybe the oil pump bolts had come loose. Well, well, well...
    Most of them are loose. These two had fallen out.
    But good news, no bits of guide and boy it sure is clean and silvery in there.
    Will put some Loc-tite on the OP bolts and torque them down, adjust oil pump chain tension, and reassemble with a new oil pan gasket. Yes I will reuse the old oil pan bolts, they are perfectly fine.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  3. #53
    IL
    2000 740i sport
    Nice catch!
  4. #54
    Rutland, Vermont
    Quote Originally Posted by purplecty View Post
    Nice catch!
    Thanks. Yeah, I was pretty damn happy to be able to address this.
  5. #55
    IL
    2000 740i sport
    I know this is a common issue on the earlier prefacelift M60 and M62s...
  6. #56
    Jun 2005
    Florence KY
    1998 BMW 740iL
    Installed new wishbones and traction struts. New speed sensor too along with repairing the male plastic connector.
    Just keeping it reliable and looking decent.
  7. #57
    Jun 2005
    Florence KY
    1998 BMW 740iL
  8. #58
    Jun 2005
    Florence KY
    1998 BMW 740iL
  9. #59
    IL
    2000 740i sport
    What wishbones did you use? I replaced both sides taking a gamble with rein from fcp and the rubber quickly cracked and now looks pretty ugly. I will definitely replace these under warranty sometime soon...
  10. #60
    Jun 2005
    Florence KY
    1998 BMW 740iL
    I used Lemforder for the wishbones and traction struts. I hesitate to use any other brand besides Lemforder on suspension components, they appear to be very well built.
  11. #61
    Jun 2005
    Florence KY
    1998 BMW 740iL
    Quote Originally Posted by haynes740 View Post
    Replaced OBD2 cover today. Thanks to subzero32 for the tip of what to look out for. Dremel with a cutting wheel is your friend to get the little lock washers off.
    Glad to help!
  12. #62
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Replaced the Ebay version LED fog light bulbs with a pair from LED Light Street. Also went with the Canceling unit to eliminate the fault check on my cluster. The new bulbs come with a built in cooling fan but are considerably bigger than stock. However the bulb housing and fan is weather proof. Based on that, a small amount of RTV was placed on the base of the bulb housing to hold in place and the back cover of the fog light housing left off while the bulbs we’re hardwired into place. So far so good. Trying to post photos.
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
  13. #63
    Oulu, Finland
    See my sig
    Not much... Installed front tires for summer setup.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  14. #64
    NYC
    99 IL/13 SXT/04 Audi A4
    Are you planning on putting the back cover on so the water does not get in the fog light
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  15. #65
    Jul 2012
    Quote Originally Posted by franco90 View Post
    No it’s all weather proof and I also have the Alpina lip for extra protection. All electrical connections or heat shrink wrapped
    [IMG][/IMG]
  16. #66
    Apr 2016
    Mass
    2016 340i XDrive M-Sport
    Both Tie Rod Ends and Center Link /w Alignment done today. Had someone do this one as I needed it for State Inspection.
    It is what it is. A labor of love!
  17. #67
    NYC
    Can you please share the link where you purchase those bad boys
    El Cid 1999 IL
  18. #68
    Jul 2012
    https://ledlightstreet.com/products/...conversion-kit
    I also purchased the decoders.
    [IMG][/IMG]
  19. #69
    Jun 2005
    Florence KY
    1998 BMW 740iL
    Finally replaced the rear window regulator. Took time figuring out how to put the glass back in. Also put in a working window shade.
  20. #70
    Jun 2005
    Florence KY
    1998 BMW 740iL
  21. #71
    Jun 2005
    Florence KY
    1998 BMW 740iL
  22. #72
    Jun 2005
    Florence KY
    1998 BMW 740iL
  23. #73
    Jun 2005
    Florence KY
    1998 BMW 740iL
  24. #74
    Jul 2012
    @Subzero, outstanding sir. i’ve been lucky haven’t had to tackle that job yet.
    [IMG][/IMG]
  25. #75
    Jun 2005
    Florence KY
    1998 BMW 740iL
    Thanks! I've put this repair off for a long time. Getting the glass out of the car and back in was the hardest part.
  1. Clayed my E38 today, results!
    By voodoomelon in forum 1995 - 2001 (E38)
    Last Post: 03-04-2022, 02:10 AM
  2. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
  3. sold my e38 today
    By mikeybimmer in forum 1995 - 2001 (E38)
    Last Post: 05-26-2009, 05:06 PM
  4. Got a sub installed in my e38 today
    By TransporterE38 in forum 1995 - 2001 (E38)
    Last Post: 04-14-2006, 09:25 AM
  5. Did I see the Infamous Turbo E38 today?
    By LLuke in forum Southwestern - US
    Last Post: 03-03-2003, 12:28 AM
