Hello to all,
I am having code issues with my X5. I have the following codes 2C32, 2DED,2DEB,2C6C, 2C2C and finally 2C2B. I have researched the codes and not really gotten any where. I have replaced all 4 of the O2 sensors, cleaned the vanos sensors for good measures. I just replaced the DISA valve as I have read that that can give different codes for the O2 sensors. I havent ran it yet to see if the DISA fixed the issue. Also, is the DISA valve suppose to be open or closed with no power. I want to thank everyone in advance.
Thax again,
Terry
It's good that you've got BMW specific codes, and not generic P-codes. However, you posted a bunch of codes and no descriptions. You have as well have posted in Latin because I have no idea what those codes mean. Always post the code with the accompanying description.
Found the issue, leaking intake gasket on bank 1
