Results 1 to 10 of 10
Thread: FUEL FILTER for my 4USBT33483LS426759
    Jan 2020
    WINCHESTER, VA.
    2003 E85 z4 convertible
    Question FUEL FILTER for my 4USBT33483LS426759
    One of the first tasks to do on the used Z4 is to figure out why it will no longer start. I wish to change out the fuel filter. MaYBE i REALLY DON'T AFTER WHAT I HAVE READ ABOUT DOING THIS. I assumed it would be an under-carriage in-line filter with maybe a built-in regulator. I keep reading about this horrendously complicated in-tank fuel filter style - scary. Q: How can I determine what type of filter to expect to see? Before I crawl under I need to know if it will be worth it! Car has only 22k miles and was running. Car sits in an unheated garage, dry but still relatively protected from the elements. Water/Ice?
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved to the model specific discussion area.
    88M3 AW 43k miles Project FS
    Feb 2013
    Canada
    2004 Z4R 06&12 Cooper S
    Quote Originally Posted by asuleske@gmail. View Post
    Yes a lot of disassembly for a fuel filter change.
    It may simply be a case of stale fuel in the lines. I had a no start condition one spring after winter hibernation.
    Bookmark this for future. https://www.realoem.com/bmw/enUS/select?vin=lt27360
    Also link to the part of the catalog pertaining to the fuel filter https://www.realoem.com/bmw/enUS/sho...diagId=16_0541
    ECSTuning is not always best price but have pictures of most parts online. https://www.ecstuning.com/b-genuine-...r/16117197690/
    04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
    Jan 2016
    Ca
    2001 525it
    Check fuel pressure first
    Jan 2020
    WINCHESTER, VA.
    Thanks. Pressure is great.
    Dec 2013
    Chicagoland area
    EXOTICS
    Has spark been confirmed ?
    Fresh new set of sparkplugs?
    Dec 2013
    Chicagoland area
    EXOTICS
    You might try also disposing of old stale fuel,
    adding a couple of gallons fresh fuel,
    along with a bottle of Chevron Fuel System/Fuel Injector Cleaner,
    Worth a try !
    Jan 2020
    WINCHESTER, VA.
    plugs are good
    fresh set OK
    Jan 2016
    Ca
    2001 525it
    Is the engine actually turning over?
    Dec 2013
    Chicagoland area
    EXOTICS
    plugs are good
    fresh set OK
    Along with the other recommendations I suggested ?
  1. Is this the right fuel filter?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2001, 10:38 PM
  2. Any advice b4 I change my fuel filter???
    Last Post: 05-23-2001, 11:38 PM
  3. Fuel filter/Water pump
    By Cock318 in forum 1991 - 1999 (E36)
    Last Post: 04-20-2001, 07:14 PM
  4. Changed fuel-filter, yesternight, God what a (+)
    By Sean~328i//EastBay in forum 1991 - 1999 (E36)
    Last Post: 04-07-2001, 08:22 AM
  5. Changed fuel-filter, what a (+)
    By Sean~328i//EastBay in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2001, 12:49 PM
