Well, as the longish title of the post says, I can't seem to get the spring compressed enough to get the strut back together on a 2000 528i touring with the Sport Suspension. I've tried both the regular regular long screw style spring compressors, and the clamp style from Harbor Freight. The piston rod from the strut extends about 6" out from the top of the strut housing, and trying to pull it out further doesn't bring it out much.
Comments on how to get this bad boy back together so I can put the strut back in the car and get it on the road again are greatly appreciated!
Thanks!
Vince
See Ross1' offer to use his wall mounted spring compressor. It will make the job simple and quick. The key is slow even compression from multiple spacing. I do not have the tool shown so I used 4 DIY worm drive strut tools. PITA as these cars have variable rate springs (wide in the middle and tight at the ends) requiring a systematic approach.
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Seconded. In my experience, I got the sport springs to compress enough with the HF clamshell spring compressor since they're about 3/4" shorter than the standard springs, but it was very tight. Getting the top mount nut to grab with all the hardware on it was tricky. HF compressor on standard springs was pretty much impossible - you could get the spring and top mount to screw together but the added compression would cause the compressor to get caught in the bottom end of the spring winding.
If you plan to do struts on more than two cars, a wall mount compressor is worth the money spent and time saved. They're also much, much safer to use.
Planning a visit to Ross' place tomorrow... Thanks for all the great info!
Vince
Meant to reply sooner, but car has been wanting more attention....
Ross is THE Guy! His compressor makes this job look much easier than it should be. So much easier that now I want to do the other side to make them even.
Vince
