Results 1 to 8 of 8
Thread: Difficulty Getting Front Strut Spring Compressed Enough to Put Strut Back Together
    Chicago area
    too many....
    Well, as the longish title of the post says, I can't seem to get the spring compressed enough to get the strut back together on a 2000 528i touring with the Sport Suspension. I've tried both the regular regular long screw style spring compressors, and the clamp style from Harbor Freight. The piston rod from the strut extends about 6" out from the top of the strut housing, and trying to pull it out further doesn't bring it out much.
    Comments on how to get this bad boy back together so I can put the strut back in the car and get it on the road again are greatly appreciated!
    Vince
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    See Ross1' offer to use his wall mounted spring compressor. It will make the job simple and quick. The key is slow even compression from multiple spacing. I do not have the tool shown so I used 4 DIY worm drive strut tools. PITA as these cars have variable rate springs (wide in the middle and tight at the ends) requiring a systematic approach.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    NNJ/NYC
    1997 528i/5, 1997 528i/5
    Quote Originally Posted by StephenVA View Post
    Search CL. I ended up buying a wall mounted compressor for $200 and the saved hassle was worth every penny. The HF compressors kind of work but aren't great for these cars.
    Wade
    Oct 2018
    Hackensack, NJ
    99 528i, 90 535i, 07 X3
    Seconded. In my experience, I got the sport springs to compress enough with the HF clamshell spring compressor since they're about 3/4" shorter than the standard springs, but it was very tight. Getting the top mount nut to grab with all the hardware on it was tricky. HF compressor on standard springs was pretty much impossible - you could get the spring and top mount to screw together but the added compression would cause the compressor to get caught in the bottom end of the spring winding.
    If you plan to do struts on more than two cars, a wall mount compressor is worth the money spent and time saved. They're also much, much safer to use.
    Jul 2012
    mitten
    525it,02 525it,73 2002
    I had to use three of the worm drive style to compress it with two people. It's sketchy at best doing it.
    You might check with a shop and see if they would swap them out for a few bucks. I think others have done that.
    Chicago area
    too many....
    Planning a visit to Ross' place tomorrow... Thanks for all the great info!
    Vince
    Chicago area
    too many....
    Meant to reply sooner, but car has been wanting more attention....
    Ross is THE Guy! His compressor makes this job look much easier than it should be. So much easier that now I want to do the other side to make them even.
    Vince
    NNJ/NYC
    Quote Originally Posted by vinceinIL View Post
    Vince
    Awesome!!
    Wade
  1. Front strut spring compressing giving me a fit
    By MrTeeThyme in forum 1996 - 2003 (E39)
    Last Post: 01-13-2014, 04:38 PM
  2. e39 528i front strut - spring compression before removal ??
    By jg528i1998 in forum 1996 - 2003 (E39)
    Last Post: 01-30-2010, 09:09 PM
  3. Eibach front lowering springs for sale, mounted, with struts, rotor mounts
    By hurley1229 in forum Suspensions, Springs & Shocks
    Last Post: 10-31-2009, 11:41 PM
  4. WTB front lower spring perches for E36 Moton struts
    By hotshu in forum Race Cars & Track Parts
    Last Post: 04-27-2007, 10:41 AM
  5. Need help ASAP. Is this spring compressed ENOUGH?
    By jameskarger in forum 1991 - 1999 (E36)
    Last Post: 04-22-2007, 09:49 AM
