Results 1 to 10 of 10
Thread: Clutch recommendations for higher horsepower e36 with a get rag 420g
    Jul 2017
    Yonkers, New York, USA
    1997 BMW M3 coupe
    My e36 needs a new clutch, figured since I'm gonna be boosting it soon (turboing not supercharging) I might as well throw in something that'll handle around 550whp, I know clutches are normally rated in torque so I would assume 550wtq is around what a boosted e36 making 550whp would make, any recommendations on a clutch thou? I was looking at the DKM e46 m3 twin disk clutch kit, since I have a 6 speed swap I have to use a e46 m3 clutch but what do you guys think?
    Also does anyone know if I need anything special since it's a different trans or would a e46 m3 clutch kit have everything?
    thanks
    Jun 2001
    hell
    turbo e36 m3/ stock s50/e30 m3
    My southbend is doing great with 684 rwtq..but not sure if they make one for your set-up...I really like the southbend even though its around 1000.00, every time you wear it out, send it back for a rebuilt and they actually send you a new kit for under 200.00..
    96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
    Jul 2017
    1997 BMW M3 coupe
    What kind of southbend clutch is it? I'll email them and ask if they have that same one for a get rag 420g.
    Is that $1000 with or without a flywheel?
    Jun 2001
    hell
    I believe it's the stage 5 ceramic. It's just the pressure plate, throw out bearing , and clutch.. You can use your dual mass flywheel
    Tampa, FL
    03' M5 & 98' M3
    Check out xclutch. I have their 9" twin disc rigid ceramic rated for 1240ft/lb of torque.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Twin disk includes flywheel and is the way to go for big power. Competition Clutch and DKM make ones that are popular for these motors. I ran the SB for years on the stock dual mass. I had to change to the fully ceramic version once I started drag racing. I recently changed to a twin disk as part of a 6 speed swap since my SB would not fit the trans.
    Jul 2017
    1997 BMW M3 coupe
    Which twin disk did you switch too? And you don’t think the organic one that dkm sells would work?
    Jun 2005
    New England
    I am using a custom setup by Spec that 22RPD put together as part of its GS6-53 conversion. I went with ceramic because I have fused clutches at the drag strip before. If you don’t drag race then organic will be fine and organic is a little easier to drive. DKM and Competition Clutch seem to be pretty popular. I know that with CC you can get ceramic if you want it and the ceramic is very driveable. A friend has the CC twin ceramic. CMS Motorsports sells the CC. Maybe others. Maybe it us the same as DKM — I don’t know.
    FL
    are slow.
    DKM is really popular with the N54 crowd. They hold crazy levels of power, and engage like a stock clutch. Twin disc is really the way to go, anything else is to have big drawbacks. There's no way a single multi-puck ceramic clutch engages anywhere near as smooth as a twin can.
    550wtq you can go anywhere from a cheap Ebay Fx racing stage 4 clutch kit, twin disc UUC (wouldn't recommend), Twin disc DKM, south bend, etc. So many good options at that power level.
    -Dr. Seuss
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    I run a single plate 850csi 280mm segmented clutch plate with modified pressure plate but I’m only holding 450rwhp and a centrifugal blower on an m60. bugger going for a puk clutch as drivablity will be awful. I’ll prob go to a twin plate setup to keep drivability good.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  1. E36 e36 clutch recommendations
    By E36DAILY in forum Drivetrain & Transmission Parts
    Last Post: 05-18-2018, 10:54 AM
  2. E36 OEM clutch + lightweight flywheel - off an E36 M3
    By Milla in forum Drivetrain & Transmission Parts
    Last Post: 08-23-2013, 10:18 AM
  3. E36 brand new UUC m5 clutch and lightweight flywheel for e36
    By skiboard06 in forum Drivetrain & Transmission Parts
    Last Post: 02-05-2011, 07:35 AM
  4. E36 NEW! Clutch Masters FX200 Stage II E36 M3 M Coupe M Roadster
    By NotUrAvgM in forum Drivetrain & Transmission Parts
    Last Post: 10-08-2010, 08:11 PM
  5. Clutch Recommendation For S/C E36 318
    By GQ_Style in forum Forced Induction
    Last Post: 12-02-2004, 01:10 PM
