Results 1 to 3 of 3
Thread: Strange problem
    Jan 2005
    Baltimore
    99 528iTA
    Strange problem
    There is a red light on the bottom of the hatch. I suspect that it is supposed to light up when the hatch is open, mine doesn't.
    It has been a little while since I messed with it but I do remember finding that the wires didn't reach the light. Strange right?
    I did not pull all of the trim off of the hatch since when dealing with 20 year old plastic things like to break and I try to do as little harm as possible unless it is necessary.
    Any one else have a problem with this light?
    Also, behind the sub woofer I have several fuses that are not in a fuse block, just wires with what appear to be factory spade connectors on them attached to factory fuses. there are about 5 or 6 of these free floating fuses. I have not seen anything like this on any other E39 I have looked at. One of the fuses is for the fuel door actuator. I discovered this when I replaced the faulty actuator and found out why it wasn't receiving power. Someone had just ripped the wire out of the spade connector.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    The wires run thru the hinges. If you pinch a wire...... you will have to trace it back. Not sure if you are the original owner. I see you are in Baltimore, but still look at your hinge condition.
    Jan 2005
    Baltimore
    99 528iTA
    It was new to me Sep 12, 2018.
    Problem has existed for all my owner ship.
    That hinge, strut, wire loom design, not one of BMW's better ideas.
  1. HID 5000K + Ellipsoids = strange problem...
    By GolGotha999 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-02-2008, 09:14 PM
  2. Strange Problems
    By KEEPYOURDISTANCE! in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-06-2003, 02:02 PM
  3. Strange problem with steering on E36 M3
    By neenja in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-09-2002, 12:28 PM
  4. Strange problem with steering on E36 M3
    By neenja in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-05-2002, 08:32 PM
  5. Please Help! Strange problem
    By Mauricio in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2001, 12:34 PM
