282/282 ..240/240@.050 .440 lift for both.
Custom profiles for m/s50/52 by paul burke ground on estas chill cast blanks.
Brand new never run in a motor.
Will require aftermarket springs
Somthing in the 90+lb range at 1.400 install height.
They will come with a cam card
And I can supply 3d printed timing blocks to make degreeing super easy and to fully take advantage of these cams for a turbo application or NA setup The common misconception is if you install bug cams it will hurt the bottom end, not that case if you degree them properly. I can make your 70+ mm turbo spool like a 35r.
Can be installed to accommodate either FI OR NA
centerlines will be different for both.
$1,650
https://ibb.co/t3mv1q3
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Hello I’m interested in these but need a little more information. I have questions about vanos, turbo limits, drivability and fuel. I currently have 22rpd built short block with 22rpd built head with super tech hardware. I still have not purchased turbo but looking at a 7275. Please contact me here or email jturbo05@gmail.com
Sold!
Sent you pm
