I'm playing with the idea of implementing an electronic parking brake into my e46 328i build when I get around to doing the hidden hydraulic brake and may buy a parking brake actuator from an e66 in the meantime to mess around with while working everything out. If anyone has a schematic or knows the pin-outs on the part it would be super helpful. If it's anything like the other electronics I've worked on, the center pins are probably grounds, the outer connections are probably positive and bypass pins.
Pretty sure you can just look up the actuator by model here:
https://www.newtis.info/tisv2/a/en/
