Hoping to see if anyone has had this problem or can lend some insight.
I took my ’94 E34 in for a transmission rebuild. 168K miles original miles on it. After receiving it and driving for about a couple of months, it began to slightly slip when changing gears from 2nd to 3rd. I took it back and they confirmed, removed the transmission and found some clutches to be prematurely burned. The original ones were severely burned, almost black. They replaced them with new ones again.
Same thing happened so they went ahead and this time totally rebuilt the valve body with the latest upgrade kit. Drove it about a week and the same thing happened again. This time they decided to swap the transmission altogether, placing the rebuilt valve body into it. Again, same problem. Because this was an entirely different transmission, they now thought it could be the transmission control module. They ordered one on eBay, last week, it arrived this morning, installed it, and the same slippage is happening.
So, has anyone out here run into this before or can guild me as what to look for next? The shop has been very cooperative and willing to resolve this issue but I thought, who know, maybe someone has an answer out here in forum land, lol.
Btw, transmission cooler and lines were blown clean so there’s no chance there’s blockage and overheating problems. No error codes at all. And the solenoids were also replaced.
Thanks in advance
How about the torque converter, was that flushed and tested?
Not come across the issue but maybe consider the differences between 2nd and 3rd gear:
Overrun clutch, 2nd gear clutch, overrun roller and 1-2/3-4 solenoid are in the same positions in both 2 and 3.
In 3, the band is released, 3rd clutch is applied and power to the 2-3 shift solenoid is switched off.
So if the 2-3 shift solenoid spool is stuck or has a lazy return spring, the 3rd gear clutch will not apply properly.
It is only a theory but it may be worth asking if the springs and spools were also changed when the VB was rebuilt
Do you have a GM 4 speed or a ZF 5 speed? Check your gear selector. If the highest number is 3 you have a GM 4 speed. If the highest number is 4 you have a ZF 5 speed.
This is important to know. Issue with the ZF 5 speed can also be too little engine torque or a certain bushing was not replaced during the overhaul. There is a design flaw in the 5HP18 that allows the 2-3 shift to flare up.
