Results 1 to 8 of 8
Thread: Heater Blower Motor
    Katonah, NY
    87 635 CSi, 88 560SL, 97
    Heater Blower Motor
    Hi All - I had to replace my blower motor transistor and the blower motor in my '87. I tried to repair the resistor myself and had no success. Also, the motor was siezed so I bought a new one without the squirrel cage assembly. So my question is how do I get the plastic blower fins off the old motor and onto the new one?
    Sep 2016
    North Florida
    1983 633csi, 2017 540i
    I just gently tapped mine off with a 1/4 inch rod tapping the center of the squirrel cage right next to the shaft. You could probably use a piece of dowel or something like that.
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Hopefully the cage isnt brittle to the point where it will be damaged once you try to remove it, proceed gently.
    Im about to try the resistor once I figure out what part I need and where it's located. Mine works on MAX only, it was working 100%, but the car sat for 20 years and some debris had gotten in it. It's all blown out of the vents for now, so hopefully the resistor is the ticket.
    Anyone have a link to the resistor?
    1985 635csi
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    Sep 2014
    asheville, nc
    89 635CSi & 87 MB 560SL
    Posted on BigCoup by Baders
    You should look up this transistor;
    2N3771G
    It is rated at 30a thus twice the current carrying capacity of the original.
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    740ilDuke, I believe that the fan control transistor is located in one of the the fan clamshells, inside the cowling. That updated part Roger posted seems like a great idea too!
    Save the manuals!
    '08 128i 6MT, '86 635CSi 5MT (B32, Motronic 1.3, WBO2, G265, 18# FW, 3.46 torsen)
    Past projects:
    '96 318iS, sold 4/23 '90 535iM, RIP 1/23 '90 535iA RIP 6/22 '91 318i, sold 7/19 '97 M3 sedan, sold 11/18 '85 735i, RIP 2/18 '92 325iC, sold 7/16 '91 318iS, sold 6/16 '84 745i, sold 10/14 '82 633CSi, traded 9/12 '90 325i, RIP '87 325 sold '89 525i, traded '87 325iS, RIP
    Sep 2014
    asheville, nc
    This should be helpful.
    Blower_Control_RepairPDF.pdf
    You'll need a stubby flathead screwdriver to make it easy to remove.
    Spokane WA
    89 635CSi, Nissan Murano
    I just pulled the cages off my old one. A little heat, NOT MUCH, and easy pressure. Tapped them on the new motor with a small plastic hammer, be sure to check and mark the location of the cages for putting them back on.
    SprCpe
    1989 635csi # 3268410
    Built in Germany with love.
    Ostatecznym maszyny jazdy BMW
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Digikey is a reliable supplier. They have it for $6.45@ plus shipping. Buy a couple, as you never know. www.digikey.com
  1. New idea: Mod your heater blower motor!
    By Zoso in forum 1983 - 1991 (E30)
    Last Post: 03-15-2006, 04:46 PM
  2. HELP! Erratic/dying A/C & Heater Blower Motor/Resistor Pack
    By IdriveBMW in forum 1991 - 1999 (E36)
    Last Post: 06-13-2005, 09:06 AM
  3. heater blower motor
    By bichmgnt in forum 1983 - 1991 (E30)
    Last Post: 03-11-2005, 09:59 AM
  4. Heater Blower motor.
    By devilbones in forum 1991 - 1999 (E36)
    Last Post: 02-15-2005, 04:57 PM
  5. Heater blower motor or blower resistor?
    By stealth M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-21-2004, 09:44 PM
