Hi I am a engine fabricator and bought out another fabricator that retired and he built several v16 engines and I am planning on buying a heavy armored m 760li that I want to add a race suspension and custom activation aerodynamic systems what do you think? I also can develop several larger billet aluminum engines in my full equipped shop so is any one is interested in larger v12s v16 you name it larger heads ect
A V12 could potentially use off the shelf I6 heads. I would be concerned about trying to get a 8 cylinder long aluminum cylinder head to stay sealed properly. Do you have any past projects that you can share?
What's the name of your shop? Where in Ohio are you located?
Post some of your previous projects.
Although I like the ideas of a billet engine, why not build an N74 twin turbo V12. In stock form, it does about 600hp. Find a used one on ebay and build up the internals. I would think 1000hp+ would be easy with this engine with larger turbos.
Trolls gonna troll. Come on guys.
I am not trolling or whatever I basically have been redoing business and shops. I want to do a v16 basically because its different and I found out about motor generators that bolt between the engine and transmission I have setup a system that can build v8s to v24 I don't want a v24 but did recently build a v10 basically 2 10liter viper engines with 4 valves per cylinder electric superchargers and hybrid turbos no lag went in a rolls royce phantom ewb with excutive strech witch my 760li is now. I hired some people from Canada witch is becoming more and more like California as far as regulations. Everything was streched the fenders hood doors 22inch b pillars longer truck active and dynamic aerodynamics suspension system steering and more. I took 2 ideas as far as engines the American way of displacement and the sofitacated engineering of Europe. I will be offering 6.0l v12s up to12.8l and 14liter to 19.8 v16 with free valve design and no accessories will drive off the engine mine is a 19.8 with 5 valves v16 with 6 hybrid turbos and each intake runner is a cold air intake and has a supercharger per cylinder I also use dual ignition system one is lazer ignition the other is a plasma ignition everything is redundant
