Results 1 to 10 of 10
Thread: Cheap inline hydro parking brake
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    So i boaght the cheapest hydro brake handle and master i could find.. I made sure that essentially it was the same as all the others available and just 150 bucks cheaper. It mocks up well in place of the stock parking brake handle. (Since thats all its intended for to pass inspection over the completely gone stock ebrake system).
    Essentially, i can fit the output on just a 3/8 after i grind down the master because the boss is too deep... So the only problem is the input boss. It is an absolutely odd thread size. It is large enough that the m10 falls in it,but a 1/4 is much too large. Wondering if anyone else has the experience to tell me what im looking for in terms of fitting or adapers.
    -Oakdizzle
    Aug 2012
    Central, MD
    1995 M3
    The input boss of what?
    You got a picture?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Could it be British thread?
    Nov 2013
    Oneida, NY
    20191224_113554.jpg the end is the feed line from a resivior or the abs, the bottom or inside is the "to caliper".. The "to caliper" is a standard 3/8th.. (I have to grind down so the fitting will even hold the bubble flare properly and tight). The end is a inverted flare. Much bigger sized. 7/16 is too large diameter. The m10 falls inside loosely.
    -Oakdizzle
    Nov 2013
    Oneida, NY
    The closest thing i found that sorta fits is a 16mm or 5/8 bolt that i think came from e36 seat rail mount. It seema to thread pitch right, but is still slightly loose diameter wise and wobbles in the boss a bit until its sunk in all the way.
    -Oakdizzle
    Nov 2013
    Oneida, NY
    -Oakdizzle
    Nov 2013
    Oneida, NY
    I emailed the seller... They replied.
    Sorry that we don't have the thread sizes on this,
    it fits for Universal on All vehicles, Modification might require to complete installation.
    is there any problem please?
    If you are not sure about the installation, we suggest you check the details in our ad,
    or asking someone professional to help you.
    Contact us freely if you have any question at any time. We are glad to assist you further.
    Warmest Regards,
    May. Seller is yellowspeed.
    Lol.. I would be mad... But i spent a total of like $25 on this. It seems good quality except THEY cant even tell me about it. Lmao.
    -Oakdizzle
    Oct 2007
    United Kingdom
    Martini BMW E36
    Maybe I missunderstood and I feel like you've already tried these sizes but here is what normally people buy:
    For fitment of hydraulic handbrakes and master cylinders
    Using GIRLING/AP/WILWOOD/OBP/Compbrake remote master cylinders
    1 x 7/16 fitment - CMB0154-L
    1 x 3/8 fitment - CMB0154-S
    Compbrake . com
    https://i.imgur.com/85v8oV8.jpg
    Hopefully this helps. I don't have the ABS anymore so can't comment since I got an older cylinder with 3 outputs.
    Nov 2013
    Oneida, NY
    7/16 was much too large. Unless what I got at advanced wasnt right.
    Oct 2005
    Canberra, Australia
    93' Turbo 325i Coupe
    I'd take it into a specialist bolt or hydraulic shop and get them to test different sizes in it to confirm its actual size.
  1. wheel of fortune noise from parking brake
    By luckybmw in forum 1991 - 1999 (E36)
    Last Post: 10-01-2001, 11:05 AM
  2. Does anyone know how many volts the parking brake is?
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 03:05 AM
  3. Is there a way to tighten the parking brake cable?
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 08-15-2001, 01:13 AM
  4. Anyone know how many volts does the parking brake send out?
    By QuestMCoupe in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:34 PM
  5. How to fix squeaky parking brake?
    By Harry in forum 1991 - 1999 (E36)
    Last Post: 08-09-2001, 12:47 PM
