Results 1 to 7 of 7
Thread: E90 328i doesn’t start just does a click noise
    Feb 2019
    Los Angeles, California
    2007 E90 328i
    So my car would kinda struggle to turn on sometimes up until it just ddnt start at a gas station.... I was wonder if it’s because of the starter as the code shows because I’m also aware that I let my battery get low because of playing music while it was off! but I’m confused on what it is. Any suggestions? If it is the starter what do u recommend I should do?
    Replace the starter. That's assuming the battery is good.
    May 2017
    Ontario, Canada
    335i E93 N54
    White94RX clearly knows his codes and what he's doing.
    Outside of codes, my 2 cents below;
    If your battery is bad, you generally get a slew of erroneous codes.
    If it's a single code and issue, yes, more likely alternator is dying or corroded high current wire connections.
    That said, your battery shouldn't die from listening to music for a few minutes at a gas station. Maybe an hour +.
    I'd have the battery properly tested. Remove it and bring to whatever free testing shops you have locally.
    Fort Collins, Colorado
    2008 328xi Sportwagon
    Battery first. The gradual problem increase screams battery.
    Jan 2016
    Ca
    2001 525it
    Then the starter
    herndon, Va
    2001 330i, 1986 Buick Grand National
    How many miles on the car?
    2010 328xi, 2004 M3, 86 twin turbo GN
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Whack the starter case a few times with something solid, as when the brushes get old and worn, they don't always make contact. If it starts, you most certainly have a starter issue.
  1. 2011 328i e90 cranks but doesn’t start 😱help!!!
    By E90328iMob in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-02-2018, 11:06 AM
  2. 2010 BMW 328i no start just click
    By Brandonmilam92 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-18-2017, 08:30 PM
  3. 1997 528i Not Starting and makes loud clicking noise
    By Raw Data in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-30-2016, 08:43 PM
  4. 1999 E46 328i no start just "click"
    By jpbmwchvy in forum 1999 - 2006 (E46)
    Last Post: 12-02-2015, 07:33 AM
  5. NO START!, just a single click from starter: x3 3.0
    By zector in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 12-01-2012, 03:33 PM
