Results 1 to 25 of 30
Thread: ► APEX | Flow Formed Lightweight BMW Wheels - Built to Perform
    California BAY AREA
    e30 M3, 335d
    Questions?
    Call: 925-245-0773
    Email: expert@apexraceparts.com
    Web: www.apexraceparts.com
    Hours: M-F 9a-5p PST
    APEX Flow Formed Wheels
    For over 10 years, APEX has been the go-to wheel for BMW enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips.
    ➡︎ Perfect fit without spacers
    ➡︎ Made to work with big brake kits
    ➡︎ 100% OEM compatibility, no extra hardware required
    ➡︎ Unbeatable warranty & 50% replacement program
    Order Now
    ARC-8 / EC-7 / FL-5 / SM-10
    Designs & Finishes
    ARC-8 - 17" / 18" / 19"
    The lightest flow formed wheel we make. Also the most affordable. A deep lug recess allows for easy access for beefy impact sockets without scratching the wheel face. Available in Profile 1 (less concavity) and Profile 3 (deep concavity). The less concave profile provides increased caliper clearance on narrow applications, while the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Both profiles are available in 17”, 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
    EC-7 - 18" / 19"
    Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in Profile 1 (less concavity), Profile 2 (medium concavity), and Profile 3 (deep concavity). Profile 1 provides increased caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide-width applications. All three profiles are available in both 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
    FL-5 - 18"
    Gorgeous flow formed lip with I-beam spokes for reduced weight. Both the inner and outer lips are flow formed to stand up to all the abuse the street and track have to offer. The spokes of the FL-5 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. Available in Shallow, Medium, and Deep lip profiles. This maximizes spoke concavity and reduces weight on the FL-5 design. Lip size is determined by offset and width, and cannot be selected independently.
    SM-10 - 18" / 19"
    Modern design with reinforced lips and I-beam spokes. Like the FL-5, the SM-10 spokes were also designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) and Profile 3 (deep concavity). The medium concavity is offered on narrow-width applications, while the deep concavity is offered on our wide-width applications. Concavity is dependent on width and offset, and cannot selected independently.
    Order Now
    Fit Matters
    The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 8.5" to 11" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
    100% OEM Compatibility
    No need to change your wheel bolts, center caps, or TPMS sensors. All APEX BMW wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug bolts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120 BMW wheels use a 72.56mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in your OEM BMW caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
    Brake Clearance
    If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" ARC-8 clears many kits up to 355mm. Our 18" wheels clear up 380mm, including the Brembo GT kit, which has long been the benchmark as one of the toughest brake setups to clear. Our 19" wheels clear even the 410mm BMW Carbon Ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
    Weight Optimized
    We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
    True VIA - JWL & Beyond
    Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX flow formed wheels are officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
    Learn more about VIA and JWL
    Additional Features
    Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
    Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
    Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
    TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
    Lifetime Warranty
    All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
    APEX Wheel Replacement Program
    Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
    Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
    Chassis-Specific Fitment Guides
    We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
    APEX Flow Formed Wheel Gallery
    Order Now
    Questions?
    Call: 925-245-0773
    California BAY AREA
    e30 M3, 335d
    Strong and Light:
    The I-beam spokes of the FL-5 and SM-10 reduce the rotational mass of these designs while also being visually striking.
    Pick up your set today!
    California BAY AREA
    e30 M3, 335d
    APEX Overstock Sale
    Too much of a good thing!
    Some of our wheels have been idling on our shelves for too long! In order to make more room for exciting fresh inventory, we've decided to put select wheels on sale! This will be an ongoing sale and the products will be updated every 2 weeks depending on inventory. Don't see the offset or width that you are after? Check back in a few weeks! You never know what might go on sale!
    Head over to our website to check out the sale now.
    Jun 2013
    United States
    2002 Impala, 1997 Jeep
    Any shipping promos on the flow formed ARC8?
    Just ended up selling my set of forged ARC-8s I bought during the group buy. Bit off more than I can chew (they were too big) and brushed clear did not look right on the car. Would love to pick up a set of flow formed ARC-8s hyper black with tires, but throwing another $2k+ and then having to pay $100 for shipping seems ridiculous.
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by mkydsm View Post
    Sorry to hear that the forged wheels didn't work out! Shoot us a PM with the new order info and your information and I'll see what I can do about shipping on the new wheel and tire order. If you'd like to to email us instead, feel free to send it over to sales@apexraceparts.com with attention Tom in the subject.
    -Tom on behalf of Eddy
    California BAY AREA
    e30 M3, 335d
    The Flow Formed ARC-8 is our lightest, most affordable wheel, which is why it’s been our best seller for over 10 years. Part of our Classic line, it's a timeless motorsport design engineered to optimize weight and strength.
    California BAY AREA
    e30 M3, 335d
    The Flow Formed SM-10 and FL-5 feature I-Beam spokes to reduce weight without sacrificing strength.
    California BAY AREA
    e30 M3, 335d
    The Flow Formed APEX EC-7
    Available in Matte Bronze Finish in select sizes
    NY
    skateboard
    Not a fan of this shade of bronze . Too dull
    ― George Orwell
    California BAY AREA
    e30 M3, 335d
    The Flow Formed APEX FL-5
    The FL-5 is our only wheel to feature dual flow forming. Both the barrel and front outer lip are formed using high-pressure rollers to maximize strength while simultaneously reducing weight.
    California BAY AREA
    e30 M3, 335d
    Hyper Black Finish
    The Hyper Black finish, only available on our Flow Formed ARC-8 model, is a great alternative to Hyper Silver. Featuring a darker inner barrel and shadow chrome like appearance, it's sure to give your BMW a stylish yet aggressive look.
    California BAY AREA
    e30 M3, 335d
    Finishing Touches
    APEX wheels are finished using a multi-stage liquid paint over a powder coated base coat. This coating process leaves lug holes, center bores and mounting pads untouched, which ensures proper fit and torque values.
    California BAY AREA
    e30 M3, 335d
    The Flow Formed FL-5
    The FL-5 was designed with a focus on maintaining optimum brake clearance without sacrificing the deep dish appearance. The spokes feature a curved design made to easily clear most aftermarket calipers.
    California BAY AREA
    e30 M3, 335d
    The Flow Formed EC-7: Born To Clear Massive Brakes
    Through comprehensive laser scanning and endless rounds of test-fitting, the EC-7 was created to clear massive brake kits. Offered in three unique profile designs, the Flow Formed EC-7 offers maximum concavity without sacrificing clearance.
    Apr 2013
    Southern California
    1998 BMW M3
    Any group buys coming up? Been wanting a set for over a year now but it’s been so long since there’s been one.
    California BAY AREA
    e30 M3, 335d
    Unfortunately we don't have any group buys planned for existing products at this time. Between recent high levels of demand for our products combined with severe shipping delays from our factory to our warehouse, we simply don't have the inventory on hand to hold a large group buy. Please do keep an eye on our email newsletter, forum threads, and social media pages however for all future updates!
    -Ian
    California BAY AREA
    e30 M3, 335d
    E92 M3 on 18" APEX ARC-8 Wheels in Satin Black Finish
    F/R: 18x10" ET25 ARC-8s in Satin Black with 295/30-18 Toyo R888 tires
    7mm spacers at all four corners
    California BAY AREA
    e30 M3, 335d
    F82 M4 on 19" APEX SM-10 Wheels in Satin Black Finish
    F: 19x9" ET30 with 265/35-19 Sport Cup 2 tires and a 16mm spacer
    R: 19x11" ET44 SM-10 with 305/30-19 Sport Cup 2s and a 5mm spacer
    California BAY AREA
    e30 M3, 335d
    Chassis Specific Fitments
    We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free, and hub centric wheel packages for everything from showroom-fresh cars to all-out race builds. All APEX wheels are made to work perfectly with your OEM hardware and BMW roundel center caps.
    F: 18x8.5" ET35 with 235/40-18 tires
    R: 18x10.5" ET22 with 275/35-18 tires
    NY
    skateboard
    ― George Orwell
    California BAY AREA
    e30 M3, 335d
    F87 M2 Competition on Flow Formed 19" APEX EC-7 Wheels in Race Silver finish
    F: 19x9.5" ET28 with 265/30-19
    R: 19x10.5" ET45 with 295/30-19
    Tires: Toyo R888
    California BAY AREA
    e30 M3, 335d
    Paging BMW owners in the Bay area!
    If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for test fitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got!
    If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
    -Ian on behalf of APEX
    California BAY AREA
    e30 M3, 335d
    In stock and Ready to Ship!
    Our production team has been hard at work this year getting our shelves stacked high with inventory for the Holiday season. In stock Flow Formed fitments for all 5x120mm BMW chassis are available. Checkout our site and order your set today!
    F/R: 18x10" ET25 w/ 285/30-18 RE-7rR tires
    Added negative camber front/rear
    California BAY AREA
    e30 M3, 335d
    BMW F82 M4 with 19" SM-10 Wheels in Anthracite
    The Flow Formed SM-10 packs high end features typically found only on Forged wheels. Knurled beading, a tough inner lip, I beam spokes and impressive brake clearance make the SM-10 an unparalleled value. Most fitments are in stock and ready to ship today!
    F: 19x10 ET25 w/ 275/30-19
    R: 19x11" ET44 w/305/30-19
    Tires: Michelin PS4S
    California BAY AREA
    e30 M3, 335d
    It's Group Buy Season!
    Don't miss out on your chance to save big on 17" ARC-8s, 18" ARC-8 and EC-7, and 19" SM-10 BMW fitments. Hit the link below to learn more:
    Click Here to Join
    Specs:
    Front - 18x9.5" ET22 and 275/35-18 tires
    Rear - 18x11" ET44 with 305/35-18 tires
    Tires - Nitto NT01
  1. ► APEX | Fully Forged Lightweight BMW Wheels - Our Strongest Ever
    By Eddy@ApexRaceParts in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 12-12-2022, 02:21 PM
  2. ► APEX | Redesigned & Re-engineered BMW Wheel Spacers
    Last Post: 05-19-2020, 05:59 PM
  3. ► APEX | Redesigned & Re-engineered BMW Wheel Spacers
    By Eddy@ApexRaceParts in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-13-2020, 07:35 PM
  4. ► APEX | SM-10 Lightweight Track Wheels
    Last Post: 12-17-2019, 04:04 PM
  5. ► APEX | FL-5 Lightweight Track Wheels
    Last Post: 12-12-2019, 05:11 PM
