Results 1 to 1 of 1
Thread: Coilovers and EDC delete/code out check engine lightI知 considering the KW V2 coilove
    Aug 2009
    san jose, ca, USA
    99 m3
    Coding out check engine light after coilover install
    Hey all I'm looking into a set of KW v2 coilovers for my 2016 535i M Sport with electronic dampening control but the EDC delete kit is about $375 and I hear that you can have the light coded out for around $100. So if I have it coded out, will I still retain the sport mode feature? Or is that completely removed? Because obviously the suspension changes will no longer be in effect, but I would like to retain the improved throttle response. Also, can the dealership find out if it has been coded? Because I'm sure that will void warranty.
    Feel free to point me in the direction of someone that might be able to help me with the coding too, thanks!
  1. can't see which code my check engine light is pulling
    By marcop3312 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2010, 09:47 PM
  2. BMW Fault Code for Check Engine Light
    By nikatkimber in forum 1991 - 1999 (E36)
    Last Post: 04-19-2010, 12:58 PM
  3. New code with check engine light
    By Jackcat559 in forum Forced Induction
    Last Post: 09-11-2007, 06:38 AM
  4. fault code for check engine light for obdII
    By Eurogp in forum 1991 - 1999 (E36)
    Last Post: 02-25-2007, 12:02 PM
  5. How do you find fault codes For Check Engine Light?
    By supercharged1.8 in forum 1991 - 1999 (E36)
    Last Post: 11-22-2002, 11:35 AM
