2011 X3 2.8
1. There's 2 screws located on the bottom edge of the inner panel.
2. There's a screw mounted behind the tweeter.
3. There's 2 screws behind a plate mounted in the hand pull.
4. All t15
5. Cut the seal with a razor blade.
6. Lower window to almost bottom to pry tabs out to free window.
7. Push window all the way up and secure with tape.
8. Replace window regulator.
9. Leaving window all the way up, activate the regulator and go up all the way.
10. Listen for satisfying "click" as the window mates with the tabs in the perfect position.
11. Reassemble.
12. Go to Starbucks Drive-Thru.
Thanks, but this stuff is way more helpful with photos.
E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
