Is there an fix for this? TIA - Jeff
One thing you can do is pull the cluster and switch the bulb out with another one that’s not used as much. Use a small flathead screwdriver to twist it 90 degrees and it pops out. I did this recently with my mileage bulb.
You could also remove it and replace it with a new bulb
