Results 1 to 8 of 8
Thread: 05 x3 triad of lights still on after new actuator & t case fluid
    Jan 2019
    Ct
    2005 x3 3.0
    So I have a new actuator gear, a new actuator motor, a fresh t case fluid change (bmw tf 0870) and I tried to manually turn the t case gear while actuator was off...it did not turn or spin freely. I still have the triad of lights on...they all come on about 2 minutes after I leave my house. What else could trigger all 3? I have functional awd I was turning all 4 tires on a snowy incline. I’m stumped...
    Mar 2019
    ATLANTA GA
    456 X3s
    Gotcha...same here,,, im experencing the same thing...heres my speculation:
    Because we both tried to turn the gear with our hand and that we replaced the part with a new one....we are now in need of the dealer's computer for re-calibration to the new part.
    The car drives fine...no other lights...i don't like it either!
    Sent from my SM-J727T using Tapatalk
    Jan 2019
    Ct
    2005 x3 3.0
    I’m actually beginning to see signs that it’s abs related that’s responsible for my lights. The rear axle shafts have a reluctor ring on them and the abs/wheel speed sensors are positioned to sense this as it spins. The axle shaft rusts over time and deforms/expands/dirties up this reluctor ring. When the sensor gets false/missing readings it throws the whole DSC system into confusion and supposedly can also trigger the triad of lights. I found contact marks on one of the rear sensors so I ordered reluctor rings and will do a full rear service when they come in. This includes cleaning the surface under the sensors, R&R of the reluctor rings on both sides and fully cleaning up the ends of the axles where these rings are seated. I’ll post my progress and any updates once it’s back together.
    Jan 2016
    Ca
    2001 525it
    Or visit a local BMW shop so they can diagnosis it correctly
    MN
    2000 BMW 323iT
    Which three lights?
    Jan 2016
    Ca
    2001 525it
    What are the fault codes
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Definitely get codes read, btw, what is the condition of the battery and electrical system?
    Regards,
    Brian
    Cave Creek, AZ
    Jan 2019
    Ct
    2005 x3 3.0
    So an update to my situation...solved.
    The rear cv shafts on my x3 had rusted under the reluctor rings...the reluctor rings deformed from this rust causing the wheel speed sensors to intermittently lose correct Hall effect signal voltage. The DSC somehow takes this interruption and triggers the abs/brake/4x4 light.
    I replaced the reluctor ring on the driver side axle but the pass side axle was too damaged due to removal and rust, so that axle was replaced completely.
    I’ve seen lots of threads where these lights were on/triggered due to a stripped transfer cause actuator (servo motor) gear. I hope this information about an alternative cause will help someone else out there chasing the issue.
    I highly recommend the foxwell nt510 or similar scanner to assist in pin pointing the potential culprit.
  1. Alternator light still on after new alternator
    By Brockallen91@ya in forum 1995 - 2001 (E38)
    Last Post: 11-14-2018, 10:07 AM
  2. Oil Light Still On After Oil Change, '04 325ci
    By tps7c in forum 1999 - 2006 (E46)
    Last Post: 07-23-2009, 07:10 PM
  3. Brake light still on after installing new pads and sensor???
    By SteveL in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-19-2007, 11:53 AM
  4. Brake pad wear light still on after replace pads
    By Isaac F in forum 1996 - 2003 (E39)
    Last Post: 08-01-2006, 11:44 PM
  5. Break light still on after pads replaced?
    By wil801 in forum 1999 - 2006 (E46)
    Last Post: 05-28-2005, 03:31 PM
