Mostly E36 and some E46 parts
I have the following parts mostly from/for E36 (1992-1999) BMW 3-series cars – typically S/M50/52 engine cars. I have some random things for E46s as well. Most everything I will let go for a REASONABLE offer – there are a few things on this list that I’m looking to get a certain amount out of. I can attest to the functionality of SOME of these parts when they were removed from my vehicles but I can’t guarantee that any of it will work 100% - most parts are used and sold AS-IS. I may have some other stuff laying around that isn’t listed so just ask if you don’t see it here.
Please send me an email request for pictures (tyler.b.hull@ gmail (dot) com) and I will send them to you as soon as I can. Parts are located in Wilmington, NC. I will ship smaller items but things like engine blocks, fenders, etc. I will not ship. I travel around the South East in my pickup fairly often for work so if you happen to be near one of my trips I can possibly deliver larger items.
Like I said, make me an offer but please don’t waste my time. I would rather throw some of this stuff out than throw my time out the window.
3x M50/52 Timing Chain Covers (one is cleaned)
1x E46/Z4 Powerflex RTABs NEW
1x E36 Full Subframe and Chassis Reinforcement Kit (front, rear, shock mounts, strut mounts
1x Synapse BOV
1x M50/52 Metal Impeller Water Pump
1x M50/52 Stewart EMP Water Pump
1x UUC? Short Shift Kit for E36
1x UUC DSSR (can measure length – I believe S50)
1x Aluminum Trans Bushing Cups (set)
1x OEM Fuel Pump Bracket with pump
1x OEM style radiator hose NEW
1x OEM radiator with tank and hoses
24x Green Top Injectors
1x S50 Oil Filter Housing
1x Tall rubber shift knob
1x 5-Speed M-tech knob
1x 6-speed M-tech knob
1x Gray Visors from E36 Coupe (set)
1x Gray Handles from E36 Coupe (3 handles)
1x Gray Interior lighting from E36 Coupe (set: map/dome, vanity, c pillars)
1x Smoked Side Markers for 97+ (set)
1x Smoked Fog Light Lamin-X (set)
2x OEM Coupe Tail Lights
1x Tie Rod Inner & Outer Set New
1x E36 Coupe Switch set (windows, mirrors, lock)
1x ASC Switch
1x Light Dimmer Switch
1x E36 ABS Pump
2x Passenger Side Bumper Supports E36
2x Coupe Mirror Interior Trim Cover (sets)
1x Coupe Side Air-Bags (set)
1x Coupe rear seat belt and buckle
1x Coupe rear seat cushions (non-M – split folding)
3x Harmonic Balancers (2 early style – 1 later style)
1x M3 front knuckles, hubs and wheel studs w/ sensors (no rotors/calipers – set)
1x 80A Bosch Alternator
1x E46 SMG Pump
1x E36 Starter
1x 1999 328is 93 Octane Tuned DME, SWEII Module, Key Ring, Pink Top Injectors and 2 Keys – No locks or Ignition (this was on my car for 90k+ miles no issues)
1x Pink Top Injectors (set)
1x 906 A/C Belt
1x KMAC rear Camber arm adjustment bushings and press E36
1x Full Pagid brake pad set for E36 Non-M with sensors (purchased for 1999 328is)
1x Rear E-brake rebuild kit E36 (low miles)
1x Rear E-brake Cables E36 (low miles)
1x E36 Window Motor Coupe
2x E36 OBD2 O2 Sensors low miles
1x E36 Heater core valve
1x E36 Slave Cylinder
2x Metal Heater Pipe for M52 (Timing cover to back of block)
2x Used T-stat covers (one plastic – one metal)
2x SAP Valve tube (SS along front of engine)
3x Motor Mount Arms (2 driver – 1 pass)
2x Dipstick Tubes w/ dipsticks (both OBD2 style)
1x OEM Shift linkage kit
1x OEM Shift Linkage kit new
1x OBD2 Fuel Lines with Quick Connects
2x OBD2 Fuel Rails
1x M52B28 Internals (pistons, rods, timing chain and lower sprocket, oil pump, pickup tube)
1x S52 Block
1x M52 Crankshaft
1x Southbend Clutch and Flywheel removed from my 513 RWHP Turbo Car (went with a twin clutch)
1x Clutchmasters Stage 1 Clutch and LTW Flywheel removed from 1999 328is
2x M52 Valve Covers
2x M50 Manifolds
1x 96+ HVAC Control Unit
1x Red Label 402 DME
1x HK Amp
1x E36 ABS Module
1x OEM Chrome Kidneys (set)
1x Coupe Center Console Trim w/ lock button cutout (96+)
1x Coupe Rear Window Trim/Seal Black (set)
1x Coupe Rear Window Glass Tinted (Set)
1x Cosmos Front Coupe Fenders from 96 M (set)
1x Cosmos Coupe Doors from 96 M (set)
1x Schwarz Rear Non-M Bumper
1x E36 6-Cylinder Oil Pan
Miscellaneous M-tech trim for coupes (exterior door/body moulding)
Miscellaneous Body Control Modules (Hi12, Low12, 12V, RMIV, etc)
Box full of miscellaneous engine parts (brackets, clips, hoses, etc.)
Also have a handful of VANOS parts for M52 (VANOS units, hoses, solenoids, sensors)
Have a handful of IACVs as well that have all tested SAT (ohmmeter and functionality)
1995 M3 Coupe - Cosmos - CES Built S52 Bottom End - JE Pistons - Eagle Rods - S52 Cams - GT3582R - SPA T3/4 Manifold - RK Tuned - 513rwhp
2016 Ford F150 SCREW - Leveling Kit and Tires for now
