2000 BMW e39 540i for Parts (approx. 151K miles)
Silver exterior / Lt. Gray interior
Pre-Facelift
VIN: WBADN6344YGM656
I was in the process of restoring this car when it ended up in the ditch which knocked off back bumper cover and damaged left rear corner panel. Battery was damaged, and it doesn't hold a charge so the car won't start. No visible damage to rear suspension, but toe for rear passenger wheel is out (tape measure check).
M62tu engine (VANOS)
Automatic transmission
A/C works
Driveshaft has new center support bearing and CV-to-Diff. Guibo is in good condition.
New water pump, cooling hoses, pulleys, tensioners and belts for serpentine drive and A/C .
Driver's side taillight (tinted)
Passenger Front Quarter Panel (Very Good)
Driver's Front Quarter Panel (Fair - Small dent hard to see in pics with lighting)
All 4 doors (have some door dings) - Windows regulators, locks, and interior/exterior handles in working condition
Front bumper has some scraps (see photos)
Steering Wheel (some wear at edges)
Rebuilt ABS
Valley pan gasket repaired
17" OEM BMW Style 32 Front Wheel Rims with Continental Control Contact Sport A/S 245/45/ZR17
(2) wheels have refurbished rims from Auto Rim Shop (both light tread wear)
(3) wheels need to be refinished (2 brand new tires / 1 medium tread wear (black wheel))
Contact me if you are looking for a specific part.
Would consider selling whole car AS IS for the right offer, but it will need to be towed.
1997 M3 Sedan - Black/Black, 148K miles
Mods: SPC adjustable rear control arms, H&R Sport Springs, Koni Sport struts/shocks, M50 Manifold, UUC tranny mounts, DDM black kidneys
Fixes: Coolant reservoir, Bleed screw, Radiator, Aux Fan, Radiator plug leak, Airbag light, A/C belt tensioner, Oil housing gasket, Windshield wiper assy replacement, Front sway bar links, Lower Control Arms/LCABs, Tie rods, Brake light switch, Power Steering leak, C33 headunit with poor FM reception, Meguires headlight restoration, Leatherique, right/left cowl cover, rear shock mounts, drivers side corner light, passenger side fog light
TODO: Motion Motorsports Underpanel, Differential rear gasket and outer seals, Stewart water pump, door handle trim, Tint replacement, rear speakers, rear subframe bushings
Previous Rides: 1998 Ford Windstar, 2000 Toyota Sienna, 2004 Honda Odyssey
Wheels are gone.
Fog lights are gone.
Need the tow hook and both cabin air filter tubes if the tabs aren't broken. PM me a price paypaled and shipped to 08527 in nj.
In need of drivers side rear window regulator & sunroof shade panel if upholstery is in good shape, mine is bare
in s.e mass
