Results 1 to 3 of 3
Thread: e64 gearbox problem
    Sep 2017
    London
    Bmw
    e64 gearbox problem
    As you may have seen on my other thread , i fixed the engine issue
    What i am left it is gearbox
    When i bought the car, after driving it home it started to slip and judder as hell and kept throwing gearbox is overheating
    Checked pan and it was leaking so changed pan and oil and that took care of it however it only works as long as you don't floor it
    You can floor it when cold and it grips but as soon as hot, it slips and judder as hell and throws error
    When switched off and on, problem would go away but if you floor it again when hot same thing
    I flashed ecu and gearbox with daten v67 and that changed things. Now it doesn't judder and slip even when hot but if you push it too much it throws error
    Tonight when revved twice it tried to shift down but it couldn't. It revved, changed gear and quickly changed back up . It did it twice and then throw error and clutch slipped
    It will no longer shift up.
    Error deleted and again fine
    So what i want to ask is , do you think it is the 4 sleeves( 3 round) and one with two square that allows fluid flow that are gone or is it torque?
    It could be also oil level. I did check though and oil was ok .
    Appreciate any opinion here
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, the seals shown in section 4 and 7 should always be replaced when the oil is changed:
    http://www.meeknet.co.uk/E64/mecha.pdf
    My BMW Repair YouTube Channel
    Sep 2017
    London
    Bmw
    All of those changed and it is still playing up
    When cold no issues and grips like hell. When hot it slips quite bad
    If it is in D and I floor it resulting in downshift then car vibrates like hell and slips
    If i changed it to manual mode/step tronic then for instance put it in second gear and floor it , it tends to grip most of the time Even when hot
    It can't be solonoid, right? It is most likely tc in my opinion
  1. gearbox problem
    By tmc in forum 8 Series (E31)
    Last Post: 11-08-2006, 11:19 AM
  2. E36 stick maunal gearbox problems
    By big six bimmer in forum 1991 - 1999 (E36)
    Last Post: 02-14-2006, 09:30 AM
  3. Sequential Manual Gearbox Problem
    By ROMA in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-27-2004, 11:38 PM
  4. 730ise gearbox problem
    By wordie730 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-02-2004, 11:06 PM
  5. Solved:MZ3 Gearbox Problem
    By clubhead in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-18-2004, 07:02 AM
