Results 1 to 4 of 4
Thread: Water Pump Swap
    Aug 2019
    NY
    85 735i
    Water Pump Swap
    Hi
    I recently changed the water pump to the screw on version by accident and now in the process of changing the fan clutch and pulley to match.
    My question is besides the 130mm pulley and the screw on clutch, is there anything else i have to change? Belts etc?
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    A 144mm pulley will work with the screw-on water pump.
    13x1055 belt.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Aug 2019
    NY
    85 735i
    Isn't 144mm the original one? The one i have now wont seat properly on the water pump. This is the one i purchased btw: https://www.ebay.com/itm/Water-Pump-...gAAOxyuCJRfNLx
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    What belt are you using? What alternator are you using? Is alt fully loose?
    I make E23 parts.
    10/1984 745i
    11/1984 745i
  1. Quick water pump swap question - 2001 740iL
    By jpilk99 in forum 1995 - 2001 (E38)
    Last Post: 03-17-2019, 11:04 AM
  2. Facelift water pump swap.
    By Sabreslight in forum 1995 - 2001 (E38)
    Last Post: 05-01-2016, 11:44 PM
  3. No Start after water pump swap,,,help!
    By g323 in forum 1975 - 1983 (E21)
    Last Post: 02-24-2010, 09:31 PM
  4. need a parts list... m20 head swap, tbelt, water pump....
    By jeepman2 in forum 1983 - 1991 (E30)
    Last Post: 12-24-2008, 08:09 PM
  5. How long does it take to swap a water pump?
    By Nemesis519 in forum 1991 - 1999 (E36)
    Last Post: 01-24-2007, 08:47 AM
