eBMWParts
Results 1 to 2 of 2
Thread: Strut Insert Test
    Oct 2008
    Boston, MA
    2000 M5
    Strut Insert Test
    I am helping a friend with his 1995 M3, he has a used front strut that he would like to use on his car to replace a damaged one. When we push on the shock/dampener cartridge by hand (no spring installed), it goes down with "some" effort but not a lot and comes back up by itself. Is that normal? It is not leaking. Is there a better way to test the shock/dampener cartridge? I know it would be best to just replace the cartridge. Thanks.
    Tom L.
    Oct 2018
    Hackensack, NJ
    99 528i, 90 535i, 07 X3
    That sounds relatively normal, but it's really the impact frequency (moving the damper rod up and down rapidly, like on a bumpy road) and not a single push that reveals damper wear. For obvious reasons it's difficult to test for that.
    Who makes the unit? If it's single-tube aftermarket, e.g. Bilstein, it's probably okay as long as it's not leaking and the rod seal looks intact. I would be leery of using a double-tube (e.g. OEM Sachs) for anything longer than a brief temporary period.
  1. Koni strut insert in E36 M3
    By M3inSC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-02-2006, 01:50 PM
  2. Dinan Koni pair of front strut insert shocks
    By BAADDOG in forum BMW Parts For Sale
    Last Post: 01-24-2003, 06:31 AM
  3. Transferring Koni strut insert
    By Rel44 M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-29-2002, 08:02 PM
  4. Koni M3 strut inserts vs non-M struts?
    By ms318is in forum 1991 - 1999 (E36)
    Last Post: 07-27-2002, 02:18 PM
  5. Koni Front Strut Inserts
    By M3inSC in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2002, 10:20 PM
