Results 1 to 5 of 5
Thread: Auxiliary Fan constantly on high speed - E46 M3
    Dec 2019
    Missouri
    2002 BMW M3
    Hello. Posting my first thread so sorry if its not the best. I have a 2002 BMW M3 6spd coupe. Recently i noticed my Auxiliary fan constantly is on max speed no matter what the case is. I start the car and I can hear the aux fan getting to speed and once it gets to max speed it stays there. Its extremely loud. I replaced the bottom radiator hose sensor so I know that's not the issue. Turning the ac on or off doesn't affect the fans speed. When i shut the car off is the only time the fan turns off. Any recommendations or suggestion? My next step will probably be to replace the fan module that is connected to the fan if i can find one online.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Probably the high speed fan relay is defective. I will move the thread to the E46 M3 forum
    Dec 2019
    Missouri
    2002 BMW M3
    Do you know where that relay is located? Thanks for responding.
    Dec 2019
    Missouri
    2002 BMW M3
    Any suggestions?
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    I don't think there is a relay...controlled by pulse width module
    Quote Originally Posted by Dvd1371 View Post
    Any suggestions?
    https://blog.bavauto.com/14421/bmw-a...nosing-how-to/.
    You should be able to search for the module location and/or testing protocol online. YouTube probably has a video.
    Also, the E46 M3 has an engine-driven cooling fan with a viscous drive element...don't overlook a failed viscous drive element that is letting the radiator/engine run hot so that the aux fan is doing much more work than it should.
    One way of testing the viscous drive element is to start the car cold and listen to the fan as the engine warms up, The fan should roar at startup indicating it is engaged, quiet down within a minute or so indicating disengage, and then roar again when engine/radiator gets hot. Similarly, the fan should not spin really easily when cold and should be harder to spin when hot, but this requires some experience with a known good drive element.
    I've had to replace an aux fan module and an engine driven fan viscous drive element once on my 2003 drive module.
  1. Auxiliary fan constantly running on high speed?
    By bumer325 in forum 1983 - 1991 (E30)
    Last Post: 11-22-2012, 08:29 AM
  2. E46 OEM 6-Speed E46 M3 Lighted Shift Knob
    By SpeedyRacer in forum Interior Lighting & Body Parts
    Last Post: 07-06-2012, 12:02 AM
  3. auxiliary fan running only high speed and does not turn on
    By boogie woogie in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-06-2006, 09:02 AM
  4. BMW M3 8000 rpm reverse indiglo gauges (high quality) E46 M3-look
    By SupaBimma in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2004, 10:36 PM
  5. High speed with M3.. i show you....
    By wooven in forum 2001 - 2006 M3 (E46)
    Last Post: 04-30-2004, 09:09 AM
