Results 1 to 19 of 19
Thread: Tranny cooling thermostat
    Jul 2017
    Turkey
    '00 540i M-Tech
    as you know, 99+ 540i's tranny uses water to oil cooling and that's ok. what is not ok is the operating temperature. a constant 100-105c is too high. ZF states that these trannies should be operating between 80-100c and not exceeding 100c but dunno why bmw designed it this way. I can clearly feel that the ride quality suffers after exceeding 100c.
    anyway, in a topic I've seen JimLev decreasing the spring tension of an engine tstat by heating it thus lowering the opening temperature. I'm wondering if the same thing can be applied to tranny tstat? I'm seriously thinking of trying it instead of installing an aftermarket cooler. That way I won't need to add extra components to the system and just use the existing cooling system.
    my target is 80-85c operating temp for the tranny.
    ps: my main radiator is good enough to compensate the extra heat. it's a hot climate version radiator. and my engine tstat is an 88c one.
    Jul 2017
    Turkey
    '00 540i M-Tech
    lol nobody has any idea... again.
    May 2010
    Allentown, PA
    1997 528 Auto 03/'96 M52
    Quote Originally Posted by TiesTorN View Post
    Not even 24 hours and you're condemning the entire forum? C'mon - you know the deal... you ask questions on your time and people answer on theirs. You won't win friends with comments like that.
    But... back on point... is this the original tranny?
    Jul 2017
    Turkey
    '00 540i M-Tech
    Quote Originally Posted by DennisG01 View Post
    nope... it's almost 48 hours. topic dropped into 2nd page.
    anyway,
    what do you mean by original? if you're asking if it's ever been rebuilt then yes, it's been rebuilt twice and cooling system completely overhauled. there is absolutely no problem with it. I'm just trying to improve it.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Heating the t-stat spring was just a test that ended up not being a viable solution.
    You can get the 85 deg t-stat or make a PWM circuit to power the t-stat heater like I did, then you can set the engine temp to what you want.
    Or...
    Put an external tranny fluid cooler in series with the tranny line.
    Jan 2016
    Ca
    2001 525it
    Or you could just gut the unit and have it run open, but I would not know if that is a good idea
    May 2010
    Allentown, PA
    anyway,
    Still, it's "nicer" to say something in a friendlier way, that's all. No big deal.
    Yes, was wondering if it was rebuilt/replaced. Reason for that was that if it was original, I was simply going to suggest leaving it as is since it's made it this far. Otherwise, I was going to ask about a lower temp t-stat - but it looks like Jim is already on top of that and he knows more about this stuff than I do.
    Jul 2017
    Turkey
    '00 540i M-Tech
    Or...
    doesn't matter how much you decrease the operating temperature, tranny temp won't change cuz its tstat opening is rated somewhere around 96c. I just wanna lower that somehow.
    why didn't it end up viable? me and my friends were seriously thinking of doing it
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    i removed my tranny stat and put a behind the rad cooler line from another beemer.. I think jcaino has also done it.
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
    Jul 2017
    Turkey
    '00 540i M-Tech
    yes, apparently he did it and he also wrote about it here while insulting me for wanting an answer lol... jimlev must have deleted those comments. it's curious why he still didn't answer my question tho.
    anyway,
    as I told him, that solution is not enough. it will keep the tranny around 95c. I need around 85c. tranny feels MUCH better at those temps.
    Jun 2015
    Sydney, NSW, Australia
    1999 E39 M5
    Mahle transmission thermostat is 86°C.
    https://catalog.mahle-aftermarket.co...76094726936055
    Jul 2017
    Turkey
    '00 540i M-Tech
    Quote Originally Posted by RosieE39 View Post
    I've seen this before and I thought that it's just what the genuine part was rated at. am I wrong? is 86c really lower than what the factory one is? cuz I couldn't find any info about the factory one.
    still too much though, opening temp should be around 75c.
    Jun 2015
    1999 E39 M5
    I’m not sure what you want or where you’re getting your figures from, but if you want your transmission to be at around 85°C then an 86°C transmission thermostat is only 1°C hotter.
    And bear in mind that an 88°C engine thermostat is the temperature of the engine outlet, not the temperature in the bottom of the radiator which is generally around 10°C cooler (depending on the application, ambient temp, airflow, capacity of the radiator etc.) which is where the transmission heat exchanger is situated.
    A 75°C transmission thermostat will result in the transmission temperature not being stable and fluctuating which is not ideal for smooth and consistent operation and gear changes.
    Jul 2017
    Turkey
    '00 540i M-Tech
    no.
    - thermostat starts to open at 86c. that means the actual temp will be around low to mid 90s
    - 88c (also starts to open, engine temp is actually around 95c) engine thermostat means the fluid circulating inside the engine will be 95c. it doesn't mean the fluid inside the radiator will be 95c. it's cooler than that while the bottom of it will be much cooler like 50-60c.
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Yes, my posts gost deleted. You don't want your tranny ATF temp lower than 80ºC. It kills the tranny life and the fuid life. You don't want it hotter than 90º on city traffic, nor beow 80ºC cruising HWY or in winter driving. The pre- TU setup does that.
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    Jul 2017
    Turkey
    '00 540i M-Tech
    Quote Originally Posted by jicaino View Post
    that's what I'm trying to do actually, but I heard that pre-tu setup is usually not enough for that. I heard that it keeps the tranny between 90-100c.
    what temps are you getting while driving? can it really keep the tranny between 80-90c ?
    Jan 2014
    Been running this setup for quite some time now. It's what you're seeking for. No pathologically lower temps on roadtrips, no overheat when drag racing or driving hard. As long as the car runs free over 30mph, the temp stays btwn 79º and 80ºC. Heavy city traffic in hot summer, hard passes or neck snapping from red light to red light in hot climate gets no higher than 92ºC Never seen anything abve 95ºC and that's when I was driving hard with no clutch fan in a particulary hot summer (new orleanish hot)
    I see you're in turkey, I recommend the 88ºC thermostat for the cooling system along with either the M5 radiator or the hot climate version. No need to go fancy and expensive on bigger,with the 88ºC it's more than enough cooling capability. I purchased a very expensive and custom radiator (cooling system holds about 20liters now) but ended up replacing the thermostat before getting to the radiator. had I swapped the thermostat before ordering the radiator I'd have stayed stock, it was more than enough even running with no visco-fan.
    Also it'simportant that you dismantle the whole front end and get good cleaning between the A/C condenser, PS/tranny coolers and radiator itself. There's a lot of debris that gets trapped there and it affects a lot the cooling performance.
    Diehard E39 driver.
    Jul 2017
    Turkey
    '00 540i M-Tech
    thx for the answer.
    yep... I have the hot climate version radiator which has considerably larger water capacity than the original.
    front end dismantled and cleaned 6 months ago, that's when my hot climate radiator was installed.
    Sep 2011
    Riverside, CA
    2004 330Ci
    Quote Originally Posted by jclausen View Post
    This is what I did on my E46. The before and after logs of coolant temp, oil temp, and ATF temp were pretty close for normal driving. I just got tired of that t-stat breaking every time I pulled the ET.
  1. NEW Perma-Cool Thermostat with Fittings
    By Jamdun17 in forum Engines, Performance Parts & Software
    Last Post: 08-22-2011, 01:57 PM
  2. tranny cooling
    By appaloosa in forum 1982 - 1988 (E28)
    Last Post: 10-08-2010, 07:58 AM
  3. Dash cluster/Cooling/Thermostat question.....(long!!)
    By mewsy in forum 1996 - 2003 (E39)
    Last Post: 08-22-2010, 07:30 PM
  4. E34 WTB Tranny cooling hose
    By vballbadger in forum BMW Parts Wanted
    Last Post: 11-12-2009, 12:06 AM
  5. tranny cooling leak
    By bmwkuruption in forum 1991 - 1999 (E36)
    Last Post: 05-14-2005, 04:58 PM
