Results 1 to 4 of 4
Thread: VC bolt seized
    May 2009
    Indiana
    88 635csi-M
    VC bolt seized
    09 335, N54, 112k miles
    Broke VC bolt between cyl 3 & 4 (over-torqued), below the head (nothing to grab with pliers). Tried to remove when an Easy-Out, but extractor broke inside the bolt (and couldn't remove). I RTV'd it up, but now (10 months later) oil is filling spark plug hole #3, causing misfire from coil #3. Looking for help on how to extract the bolt.
    1. Pull head and replace, or drill - god please no
    2. Oversize drill-out bolt, and helicoil - can I drill through the Chrome-Moly Easy-Out?
    3. Weld a rod and nut - I only have a MIG, and am concerned the Chrome-Moly Easy-Out will pose a problem. Any advise? Also not sure how I can weld into the hole without damaging the surrounding head material. Any advise how this could be done in-chassis?
    4. Some other solution that makes the coil pack robust to the oil, as a band-aid
    88 635sci project car
    Drill it out or replace the head. I bet you learned a difficult lesson. Maybe use a torque wrench next time.
    May 2009
    Indiana
    88 635csi-M
    Update for future searches:
    The oil leak was not coming from the missing VC bolt (as diagnosed by Dealer). It's coming from the oil fill gasket - ordered a replacement (will update with results).
    No oil was leaking anywhere near the missing VC bolt, which was near Cyl 5. RTV has held up well for about 6 months! We decided not to drill out the stuck bolt, with concern that messing with it (now) will do more damage then good. If it starts to leak, we'll revisit drilling.
    I'm highly suspect the oil leak is causing misfire on cylinder 3, as BMW diagnosed. I'm weary of an intermittently faulty COP. That said, I could see oil filling enough of the spark plug bore to cause intermittent connection with the spark plug (seems unlikely). In any event, we've decided to fix the oil leak, then monitor for recurrence.
    May 2017
    Ontario, Canada
    335i E93 N54
    Glad you found the source in a more definitive manner.
    Good approach on correcting leak and then reevaluating the misfire.
    I used to have half my sparkplug wells wet with oil until I corrected VCG and OFHG. So common it's a given effort at an age.
  1. e36 caliper carrier bolt seized
    By Acadiasparta in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2015, 12:21 AM
  2. e36 328is trailing arm bolts seized
    By hammy1 in forum 1991 - 1999 (E36)
    Last Post: 04-05-2013, 12:55 AM
  3. Shifter Bushing Bolt Seized Half way Out
    By Jhoss in forum 1983 - 1991 (E30)
    Last Post: 08-06-2010, 08:41 PM
  4. Oil filter canister bolt seized
    By boutner in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-18-2007, 08:35 AM
  5. Camber bolt seized
    By M3E36 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-30-2007, 03:12 AM
