Results 1 to 2 of 2
Thread: Trailing Arm Bushing Removal
    May 2005
    Blue Heaven
    E23, E32
    Has anybody found the proper tool for getting these out?
    I've tried a variety of things including the 'Advance million piece loaner tool' and can't find anything that diameter.
    Would rather not have to cut and otherwise maul the trailing arm to get them out and they are definitely in need of replacement.
    Thanks all!
    -Larry
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Erwin did it: Trailing Arm Bushings - 20 Tons is not enough http://www.bimmerboard.com/forums/posts/503785/
    "So on Friday I went to Great Hills Automotive. They aren't BMW specific, in fact the shop was full of vintage corvettes, a cobra, and assorted other muscle cars, but they have a reputation for excellence and honesty. The guy there said he could do it in an hour, no problem ($85/hr), but not today, has to be Monday. Then he went on to mention he wouldn't use a hydraulic press at all, but a c-clamp ball joint press, and that he would freeze the bushings first to shrink them. Really? Yep, 2 hours in the freezer, some anti-seize, and they go right in. He told me this fully knowing I might go try it and not come back. He was right. Turns out you don't need tonnage, just a $30 tool, and some cold air" http://www.bimmerboard.com/forums/posts/507089
    trailing arm bushings dimensions http://www.bimmerboard.com/forums/posts/506762
  1. Trailing Arm Bushing Removal
    By MarkF in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-22-2011, 09:55 AM
  2. Replies: 0
    Last Post: 10-04-2008, 04:49 PM
  3. Trailing Arm Bushing Removal ?
    By Power of M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-06-2008, 06:47 AM
  4. Trailing arm bushing removal
    By zeehaa in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-16-2007, 09:06 PM
  5. Real Trailing Arm Bushing removal tool??
    By golfaddict in forum 1992 - 1999 M3 (E36)
    Last Post: 11-05-2002, 08:35 AM
