looking for M50 ms41 OBD2 turbo tune setup for high boost.
2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
Im still looking, Anyone?
22rpd
1989 535i - sold
1999 M3 Tiag/Dove - sold
I have a rk tunes tune for low compression pistons and 6266 and everything deleted as far as emissions and ews of course. Made 600 to the wheel on pump gas. I have brand new 60lb injectors and the maf with it as well. If interested pm and let's talk. Thanks.
Sent from my Alcatel_5008R using Tapatalk
Im still looking....
Sent 22rpd two emails never heard back from them. Guess there not interested.
What’s your email?
Are you sending to Info@22rpd.com?
I can take care of you directly
(We did reply back to your emails, maybe we got sent to spam!)
1989 535i - sold
Sent you a new email Friday 10/04/2020 to Info@22rpd.com ATT:Vollosso.
Thanks.
1989 535i - sold
I have a 22RPD OBDII tune + HFM + MAF pipe + 60lb injectors for sale if your interested.
1997 M3
1999 Z3 M Coupe - Turbocharged
Vollosso, I tried to PM you, your inbox is full.
I have an RKTunes setup with injectors and MAF if interested
1989 535i - sold
