Results 1 to 2 of 2
Thread: Questions about swapping M52B25 (from E39) into 316i compact (M43B19)
    Oct 2019
    Croatia
    E36 318ti 1996 Hellrot
    Hi everyone,
    I have a few questions regarding the swap.
    I want to swap M52B25 from E39 (single VANOS) to E36 compact with M43B19 engine currently in it.
    I still haven't bought the M52 because a friend told me you need to change multiple things on the engine to fit (alternator, engine mounts, engine loom from E36....). The swap should be perfect since I will be taking the car to the MOT certificate (Croatia; also called atest), the OBDII and everything should be in working order.
    Does anyone have a list of everything I should know/consider before doing the swap or even buying the engine?
    Thanks in advance!
    NW suburban Chicago
    hiss by my window
    E39 oil pan is different(front sump) than E36. All bracketry, wiring loom and engine management computer, coolant hoses, intake pluming and air box, exhaust manifolds, cats, pipes, trans, shifter and driveshaft and probably lots more.
  1. Oil pan question, swapping m52 from e39 to z3
    By DrWho in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-06-2010, 03:36 PM
  2. Question on swapping Clusters and affect on RPM reading
    By GENE328is in forum 1991 - 1999 (E36)
    Last Post: 06-23-2003, 03:19 PM
  3. Question about swapping ECU
    By 99M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-04-2002, 09:40 PM
  4. Couple of questions about swapping seats in my 95 M3
    By Sacramento M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-17-2002, 11:42 AM
  5. Questions Regarding Swapping out Stock Head-Unit
    By scottsby in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-27-2001, 08:49 PM
