Since you were doing a Bench Test (no pun intended) and it blew the fuse on your bench power supply, it has exceeded the current rating of the fuse by a LOT. 90% of the time, this is due to a stalled motor ("ramps" up to blow the fuse). The other 10% is due to a dead short (instant blown fuse).
https://www.newtis.info/tisv2/a/en/e...driver/beaiJeb
Fuse F15 (30A) supplies power to all of the motors directly and to the SM/LSM (Seat steering adjustment) Control Unit on Pin 25 (Connector X653, Red/Brown). Pin 24 is Ground (Brown). Pin 2 is P-Bus (for Peripherals) communication (Blue/Red). Signal outputs to motors are pins 15, 18, 19, 20 and 21. All signal pins supply 12v+ when their respective switches are activated.
I'm gonna take a guess and say that you accidentally dead shorted power to ground, which popped the fuse in your bench supply. The fuse did its job. With how small these pins are (smaller than GM Metripack 150), it wouldn't be hard to short out by accident. Disconnect everything from the Bench Supply and try it in your car again as AphroditeDufour suggested
Connector Pinout is here:
https://www.newtis.info/tisv2/a/en/e38-740i-lim/ZDaUmKg
At the end of the day, each adjustment is just a polarity reversing DC Motor, no different than the power window motors. The only difference here is HOW it turns switch inputs into the appropriate actions.
2001 740I M62TUB44: Iris, My daily
1997 Ford Expedition XLT 5.4L 4x4: Onyx, the 315k mile tow rig
