Results 1 to 4 of 4
Thread: Hydraulic brake servo unit
    Feb 2019
    Fredericksburg,VA
    1979 BMW 733i
    Ok, so I have far too much ATF leaking from the union of the brake servo unit where it mates with the brake master cylinder. Has anyone take one of these apart and can enlighten me on what is inside and how to get into it? The master cylinder is not leaking at all.
    This servo is item #1 in this... https://www.realoem.com/bmw/images/diag_3gf.png
    The master is unnumbered in this: https://www.realoem.com/bmw/images/diag_3eo.png
    These are from these pages respectively... servo: https://www.realoem.com/bmw/enUS/sho...diagId=34_0267
    and master: https://www.realoem.com/bmw/enUS/sho...diagId=34_0122
    This is on my 1979 733i. I would assume there are some O-rings and sliding spindles of some sort.
    Thanks,
    Scott
    1979 733i
    Quadratechtown, PA
    5, 7, 4x4
    Feb 2019
    Fredericksburg,VA
    1979 BMW 733i
    Spectacular! Perfect thanks a bunch.
    Scott
    1979 733i
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    I second Jay. He does great work for the community.
    FWIW, if you are in there that far you should replace all the low pressure hydroboost lines at minimum, too. Due to age of our vehicles, consider rebuilding the high side hoses.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
  1. E31 Hydraulic brake servo unit
    By Mr.Lazarescu in forum Parts for Sale
    Last Post: 01-23-2014, 12:27 AM
  2. Hydroboost Brake Servo Unit Leaks
    By ruprectgern in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-06-2010, 01:58 AM
  3. hydraulic brake servo available?
    By 8Harry8 in forum 8 Series (E31)
    Last Post: 10-07-2009, 06:36 PM
  4. Help in finding the sticky on the Brake servo unit.
    By MaitreG in forum 1976 - 1989 (E24)
    Last Post: 07-08-2009, 03:31 PM
  5. bmw 840ci brake servo unit
    By 840ci in forum BMW Parts Wanted
    Last Post: 02-19-2009, 10:16 AM
