I bought some suspension seats being that this is going off road. The new seats are quite a bit bigger than the fiberglass ones I used to mock up some detentions with. so I shortened the shifter and had to re figure some of the upper cage and some of the side to make enough room.
I moved the cage higher and further back.
Well to be honest, I was first thinking of using the turbos I already have. I wanted at least 300hp but the more I thought about it, I figured I might as well just go for more if I’m going to buy a bigger turbo.
I think I would like to get around 500-550hp I’m thinking e85 with a gt35r might get me there, but I don’t really know.
It is definitely better on the budget to set it up once with the right unit. I think you would be very well suited with a Billet 6268. Depending on how you setup the suspension a 6274 will help control the "hit" in the midrange. Will come on a tad softer, but hold the power better to redline. This will be better in a traction limited setup. I honestly don't think you need that aspect of it however, it is easier on the rods, and better efficiency helping the VE up top. Both turbos will get you there no doubt and they can be rebuilt at home with less than $100 in parts if you ever have a mishap. They are very tough and we never have had a failure to date. They are considered budget units but it is a premium product.
Whatever you do, this thing will be rad. Happy to assist you further if needed, just shoot me a message here or on Instagram.
Absolutely, thanks for your input. I don’t know much about turbos, that’s why I posted the build here. Who sells the ones you are talking about and Should These have certain housings? And you think the 6274 will be best for my application with the spec’s I have listed on page one?
Also when I was looking for 300hp I was advised to just stick with my M52 manifold. Being that I’m now looking for 500-550 Would it be even better with the m50 manifold for this power level?
