Results 1 to 2 of 2
Thread: Dipstick replacement
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Asking for a friend,
    what the modern replacement for the M10 dipstick? The rubber is all hard and isn’t secure in the tube.
    Jan 2005
    Mile High, Colorado
    '76 2002,'16 435iX GC
    M10 dipsticks had several different design variations over the years. If your friend has the one with the dual-clamped rubber hose section, as found on earlier 02s, the easiest thing would be to replace just the rubber section. My 76 has a solid bent tube pressed into the block (no rubber section), but it’s too big in diameter to fit the dipstick hole in the earlier blocks. Later M10 dipsticks as found on the 3-series (E21/E30) are too short in an 02 - due to oil pan differences.
    I’m not so sure there’s a “modern replacement”.
    Here’s two links to BMW2002FAQ threads on 02 M10 dipsticks that hopefully are enlightening...
    https://www.bmw2002faq.com/forums/to...tick-question/
    https://www.bmw2002faq.com/forums/to...tick-location/
  1. Replacing your oil dipstick O-Ring
    By slopokdave in forum 1992 - 1999 M3 (E36)
    Last Post: 08-04-2023, 01:44 PM
  2. 1999 528i intake hiss after CCV and oil dipstick replaced
    By becauseracebike in forum 1996 - 2003 (E39)
    Last Post: 04-03-2015, 09:13 PM
  3. 540i Dipstick - Replace with 740i?
    By zippinbye in forum 1996 - 2003 (E39)
    Last Post: 12-09-2012, 03:57 PM
  4. Engine Oil dipstick o ring replacement
    By se93 in forum 1999 - 2006 (E46)
    Last Post: 09-03-2011, 02:27 PM
  5. Replacement V8 Dipstick.
    By 8Tech in forum 8 Series (E31)
    Last Post: 05-19-2008, 12:51 PM
