Results 1 to 2 of 2
Thread: Interior lit door handles Retrofit questions
    Oct 2008
    Madison, AL
    Check the Signature
    Ok, so I have a 95 with no puddle lights and no lit interior door handles. I was able to snatch a full set from a parts yard years ago. I am now FINALLY taking my DD 750 offline to do the upgrades along with door speakers and window track greasing.
    Anyway, I spliced the wire for ground, no issue. The Gray with red stripe that I pulled from the bone yard DOES NOT power the bulb in the older 7. I know the power command comes in from the smaller black connector, I believe its the blue wire, since its the illumination wire in the radio?
    I know someone on here has done this upgrade, but I can't remember their name, but does anyone know the correct wiring for the older cars to retrofit the interior warm glow?
    I am going to wire the puddle lights to the courtesy light at the bottom of each door wiring harness, should be just fine there, unless someone has a different idea.
    I will post my findings if no one else can remember.
    Present:
    '96 750iL (Project)
    '95 C1500 350 V8
    '03 540i M Sport AT
    '22 GMC Sierra 1500 DD
    '92 Olds Toronado Trofeo (Project)
    Past:
    '93 325is (Parted)
    '95 840Ci (Sold)
    '86 735i (Parted)
    '02 Z3 3.0i (Sold)
    '09 328i (Leased)
    '91 750iL (Parted)
    '00 Z3 2.5i (Sold)
    '86 944 NA AT (Sold)
    '84 633 CSi (Sold)
    '06 X3 3.0 (Sold)
    '20 M2:Competition 6spd (Sold)
    May 2017
    El Paso tx
    98 750il, 77 Jeep wagone
    I have a set of FL lighted handles and harnesses. Handles are Titan silver if interested.
    But for a quick fix, can you just tap the illumination on the window switch for each door?
  1. E38 Interior Lit Door Handles
    By arturb in forum Interior Lighting & Body Parts
    Last Post: 09-25-2018, 06:41 PM
  2. interior door handle pull question, loose on one side.
    By SamGrant951 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2014, 11:19 AM
  3. Exterior/ Interior door handle lights - Question + Pics
    By cwise12 in forum 1996 - 2003 (E39)
    Last Post: 11-15-2012, 01:21 AM
  4. interior door handle quick question
    By kippy183 in forum 1996 - 2003 (E39)
    Last Post: 01-31-2012, 04:28 PM
  5. WTB: Saddle Brown Interior Passenger Door Handle
    By EFreak in forum 1975 - 1983 (E21)
    Last Post: 06-29-2005, 08:30 PM
