Results 1 to 7 of 7
Thread: Saw Steam coming from Kidney Grille
    Sep 2014
    New York And CT
    07 Tundra, 02 530 14 x5
    So as I was doing my transmission service. And warming the fluid up to temp so I can top the tranny fluid off. I noticed steam from my kidney grill. Definitely smelled like coolant. Are the n55’s probe to coolant leak from this area?
    2002 525i
    FL
    are slow.
    Quote Originally Posted by Trainwreck914 View Post
    They aren't prone to leaks really, but coolant can leak if an o-ring fails, or some plastic cracks.
    Common areas to check: Radiator (usually the top0 crossover pipe, expansion tank seam, expansion tank cap, turbo coolant line orings.
    -Dr. Seuss
    Aug 2011
    Spain
    125i Coupe
    Mine has the same problem. I think it can be related to some pore in the radiator...
    My ex E82 had the same problem... I had to refill the coolant every 2 years or so.
    Enviado desde mi SM-G975F mediante Tapatalk
    Sep 2014
    New York And CT
    I’ll have to check those areas. Would hate to get stranded far from home. Thanks. Funny thing is I did not notice it today. The temp was 15-25 degrees warmer than yesterday.
    2002 525i
    Jan 2016
    Ca
    2001 525it
    Even BMW all aluminum radiators leak, like the ones in e70's etc
    Sep 2014
    New York And CT
    Did a bunch of running around yesterday. Multiple trips. In town and highway and nothing. Haven’t seen it again.
    2002 525i
    Jul 2013
    N.C.
    11 550i
    Trust me its gonna show its face again. I own a 550i and had all my coolant issues just addressed for a hefty price. At first mine started just to steam out of kidney then it started doing it every time i drove it. My car has several coolant lines, and I am assuming you have a 02 525 if you have never had any coolant line issues or radiator issues your lucky. If its just a line leaking then you will be ok to address later, unless you are adding coolant every week, if it a radiator leak I would address it immediately. Also as the weather get cooler hoses contact and could just of leaked a little due to that. May need to tighten a hose clip.
  1. Steam from kidney grills in hard rain/after wash
    By TEPPSU in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-21-2008, 02:22 AM
  2. How hard is it to do update the kidney grill?
    By Disco Stu in forum 1991 - 1999 (E36)
    Last Post: 05-19-2001, 11:05 PM
  3. How do you remove the kidney grills?
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 04-19-2001, 10:06 AM
  4. kidney grill
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 04-05-2001, 01:05 AM
  5. Kidney Grill Question...
    By Snappie in forum 1991 - 1999 (E36)
    Last Post: 03-27-2001, 02:31 PM
