Results 1 to 5 of 5
Thread: 2001 E46 330i Koni Special Active shocks with Eibach Pro Kit springs - REAR TOO LOW?
    Jan 2006
    NYC
    89 535i/5 + lots mor
    Hi All
    As the title says, I ordered Koni Special Active shocks with Eibach Pro Kit springs for a 2001 330i, 4dr, no sport package or ZHP. Front setup is great, rear is too low to drive on stock 17" rims with 205/45 tires, see pic.
    Now, the vendor is telling me the Koni Special Actives are only for stock springs not to be used with Eibach lowering springs. I know the Special Active shocks were previously the gold painted FSD shocks and were recommended too run with the Pro Kit. Theres a lot of e46 members complaining the combo didnt achieve low enough results and they would even leave out some of the rubber coil seats to get it lower.
    I had to put the stock coils back in with the SA shocks just to get it driveable.
    What did i mess up?
    Jan 2015
    Belgium
    e32 730i
    Dude I have no idea what you did, but that rear drop looks nasty. Shocks have nothing to do with ride height (in the rear) as they sit separate from the springs, but you probably knew that. I have eibach pro kit springs which sit a lot higher than this.
    This is how mine sits. Top was H&R, bottom is Eibach pro-kit freshly installed (dropped about a little less than a centimeter llater on)
    Aug 2013
    Søborg, Denmark
    2001 E46 325ti Compact
    Can you lift it up, take off the wheel and take some pics of the install in the rear?
    Dec 2019
    Cape Town
    BMW Z3
    Yours seems indeed higher than normal. Looks great! do you have any videos on how that was done?
    NoVA
    97 M3
    Does the E46 have the different height rubber insulating pads for the back like the E36? Maybe yours are too thin and you need to up them to 15mm or something.
    '97 M3/2/5 Lux, AW/Modena, ~225k, many mods and lots of grip
    Please lift when giving a point by
  1. Koni fsd shocks and Eibach pro kit springs
    By trtman in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 05-09-2012, 03:05 PM
  2. Bilstein Touring Shocks With Eibach Pro-Kit Springs ?
    By anxious in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-25-2008, 07:50 PM
  3. FS: e36 non-m Bilstein Sport shocks and Eibach pro-kit springs
    By turbodefrost in forum Suspensions, Springs & Shocks
    Last Post: 11-19-2007, 03:02 AM
  4. FS: Bilstein rear shocks and Eibach Pro-kit springs
    By TIMSGT in forum Suspensions, Springs & Shocks
    Last Post: 02-23-2007, 10:40 PM
  5. FS: Bilstein rear shocks and Eibach Pro-kit springs
    Last Post: 02-15-2007, 09:59 PM
